MIB3 update not working.
Jun 8, 2024
Hello everyone.
I'm trying to update my Arona's MIB3 from 0782 to 0870 using files from mibsolution. The update finishes normally as if everything went ok without any errors. But when i've checked the version after rebooting I found that it still on the old version. When i tried for a second time i noticed that all items in the update screen shows N/A as you can see in the below screenshot. I've tried to update to 0841 instead but still getting the same results.
Any idea what is the issue?
My current version:
I tried to look there but got stuck at the logon screen. How did you create your account as I can’t see any options
You should use UN: guest PWD: guest
But for some reason it does not work now! Maybe they are fixing something at the moment. Wait for a while and try again.
rageuk
49
West Yorkshire
Ah yes I’ve tried on computer and it says that on phone it doesn’t. Hopefully it will be up again soon.
Jun 3, 2024
Can I ask where you got the update from I’m trying to find the update for my tarraco
Hello everyone.
My current version:
Hey, are you talking about the 60 mo zip file ? Because thats the only file i found on mibsolution.
Tell
Hello everyone.
My current version:
For what it's worth with worth on mib2 high the N/A means not applicable, no work to do and suspect the last Y means it's seeing the update script only. It thinks you have it already / don't need it I'd say.
Problem with the mibsolution.one files is there will be a back story but that isn't given as to how to use all the files there. It's a dump library. @East Yorkshire Retrofits that sells ($) some of the files provides hand holding within the charge, other than that you need to search out the information. I pass on this one. Don't have mib3.
Note ($) did, its now a personal service at their location.
Jan 29, 2025
Hello everyone.
My current version:
Did you found any solution? I have Identical problem in my Tiguan
Sep 22, 2022
15
i'm not sure about it but you might need to update prior version like 0841(also avalible on mibsolutions) and then to 0870, i had such thing with software relatred thing in the past (not car related though)
*this is just a guess am in no way an expert or professional (means i take to responsibility if anything bad happens)*
**i updated my ateca from 0841 to 0870 using files from mibsolutions
Jan 29, 2025
I tried many times with all posible version of new software. Even when i get text "Software updated succesfully" car show still same wersion 0782. Same with map version - i cannot upgrade from 19.11 version. It looks very strange
Tell
I'm using Mac. And always deleting hidden files - what else i need to do ?? What i need to do with cleanmydrive?
Macs write like an extras carriage return or line feed some Mac file nonsense to the files. The firmware, map and radio logo files are all signed with SLA signatures so if the files aren't as manufactured and signed by VAG the unit won't see them after doing an SLA signature check. It will just sit there and do nothing.
Why in mib2 high and mib3 the VAG notes are use CleanMyDrive on a Mac. You copy the files across onto the drive then run CleanMyDrive it then dusts off all the Mac stuff taking out the excess material added by Mac. You might not have removed all of it inside the files.
They were using SLA1 on mib2 high... they have upped that now to a higher level of encryption.
For info here:
The cars infotainment unit has the public key built into it. All VAG cars have the same public key least they did for mib2 high. Only VAG knows the private key. You need GCHQ / NSA computer power to reverse engineer the private key by brute force methods. Signing the files is put in to protect integrity of the files from modification or transmission error.
The signature you can see by a bank of codes. The mib2 enthusiasts found a backdoor into mib2 units via the POI import so could manufacture firmware files without the signature. The all in one files recomputing the metachecks having taken out the signature and adding the kitchen sink as well, FeC update, Gracenotes etc. Vag got wise to this and took out the poi import from mib3 and the user radio logo import as straight user generated files. Why you can't import your own radio logo graphics as mib2. Part of the overall lock down within mib3. 🔐 I'm told you can still do on the bench stuff. That isn't locked down so well.
Jan 29, 2025
For info here:
I tried to do like you wrote. It is again the same - When i put usb drive with new maps from VW site it is only restarting whole infotaiment during driving but maps doesn't update. I don't know what to do :(
Tell
Adaptor is the other thing. A usb-a to usb-c some of them aren't wired for data just basic voltage. Apparently data ones are sold with data marked up. The reversible sticks are liked and those with a flashing LED so you know when there is data activity.
trucchi
10
Hello everyone.
My current version:
Hi, Could you tell me the path where to find the file to download version 0870?
I had already updated my SW to version 0841 and I wanted to update again to be able to have the android auto connection with wireless.
trucchi
10
Ciao , did you manage to update your Arona's MIB3 to version 870?
I downloaded the MOI3_EU_SE_R8700L MU0870 file but then I can't extract the files to install it. Could you explain to me how you unzipped the files?
Then did you put everything in the USB_C stick and launch the update?
Jan 12, 2025
10
Hi, if I may borrow this thread. I have a '23 Ateca Xperience with MIB3 version 0837. From what I hear now there's already version 0883 out there but there doesn't seem to be any way to do an OTA update from what I've been trying. Can someone please help?
