Locking car with key fob
PastyBoy
50
wheres the FAQ thread for this infomation on what i need to do?
from these posts
you can try it with any mk2 style remote by the way to test it just make sure if you borrow a mates that he codes it back to his car after
4 - if all the above tried to no avail a friend with a same style remote is handy as they can be programmed to your car to test it and vice versa - just remember to recode it back to his/her's after
i believe that you can remove and dissasemble your original key to seperate central locking remote and key part-> so you can use someone else's remote(not the whole key). it's done in 10 seconds or less
yes just the remote secion pulls out
I gather it's just a case of finding a similar key (which you know works) popping them both into 2 parts (blade and remote) swap the blade from your non working key onto the remote bit of the working key.
Do the turn on, turn off, press 3 times, flash 5 times routine and it recodes the remote to work with your car and should lock/unlock and work correctly.
If that happens your key is fecked and you need a new one.
If that doesn't happen then your receiver is fecked and you need to start searching scrap yards for breaking ibizas with working central locking
Ads_Vag
If in doubt... FLAT OUT!!
Feb 23, 2011
479
Warrington
www.extremebhp.com
ive got 2 key fobs, one that opens the doors and the other starts the car.... and my central locking does work... the fobs wont unlock or lock the car, thats where i have to use the key in the door to unlock and lock them...
PastyBoy
50
ok then let me rephrase
...start searching scrap yards for cards with working remote central locking
I'm in exactly the same boat and am just trying to help!
I have a standard non blippy key which does what it say on the tin.
put in door, turn, activate central locking, unlock both doors and the boot, put in ignition, start upm drive away.
My remote blippy key does all of the above too. exactly as it should
However you stand next to a locked car and push the iunlock button the light flashes but nothing happens. Stand next to an open car an push the lock button an equal amount of nothing happens.
Either the sender in the key is dead - which is where testing it with the remote part of a different key comes in.
Or the receiver in the car is dead - which is where finding a replacement from a scapper comes in
3,221
cannock
or airbag whichever you have, well as i say the other half is going to replace the box at the weekend and we do have a spare key so see what happens i will let you guys know
if i remember i will get the box out the shed tmoz to show you what it looks like
Ads_Vag
Feb 23, 2011
479
Warrington
www.extremebhp.com
ok mate makes sense :) ill have get searching scrap yards then for a transponder for my car and you know the sender in the key is that the little chip or the little like motherboard thing lol...
Aug 22, 2008
3,221
cannock
yes its a tiny chip thing that i once lost and after hours of waiting for the rac to come out try to fix her , i then remembered the key fell apart oooooops i did feel a prat luckaly it was on the driver seat
PastyBoy
50
if it dont work when i try it again tomorrow, is this what im looking for on ebay? : http://cgi.ebay.co.uk/SEAT-ALHAMBRA...ps=63&clkid=8411799086253105817#ht_521wt_1139
Get your mitts off. I had my eye on that one :)
Yes though in theory the remote section of that would swap straight onto your key.
However as you are buying just the key you have no idea if the trasmitter inside that one works or not.
It could turn up and still not work but you still wouldn't know if you'd finally confirmed the receiver in the car is broken; or if you'd just bought another duff key :s
Ads_Vag
Feb 23, 2011
479
Warrington
www.extremebhp.com
YES!! :D considering its taken so long to try and figure out the problem, i finally did dismorning!! :) i had a brain wave last night so thought i'd change the fobs over on the keys and hey presto it worked!! :D :D i can now unlock n lock the car without using the key in the door :) but should the indicater lights flash when you lock the car lol? By the way thank you for everyones help much appreciated :)
