Locking car with key fob
Ads_Vag
If in doubt... FLAT OUT!!
Feb 23, 2011
479
Warrington
www.extremebhp.com
just reconnected the battery...
1.key in
2.turn to the ignition lights
3.take out straight away
4.hold down one button and press the other 3 times with a pause between each press
5.then the key flashes 5 times
but still doesnt wanna lock or unlock the doors from the fob :( :(
really getting annoyed now lol...
PastyBoy
50
sounds like the same situation i'm in
had the car just over a month and after a couple of days of disconnect & reconnect , ignition on, ignition off, buttons pushed, LED's flashed, and on about the 50th attempt finally getting the 5 flashes but no response from anything else.
I have just found that my key only has a single battery in it but given i've had the 5 flashes I can but assume dead transponder or receiver.
Opening the car with the key isn't exactly the worst inconvenience in the world but is changing the transpoder (in the key I assume) or the receiver (in the headlining/interior light?) easy?
PastyBoy
50
ah ok so the 5 flash just means its trying to transmit but if it doesn't have the power it can't send anything so isn't likely to stir a response out of the central locking.
I shall pick up a couple of new batteries ASAP (and probably be back when it still doesn't work :D)
PastyBoy
50
Ads from the info posted here and in the FAQ thread if you still aren't getting a reponse you either have a knackered transmitter in your key or a knackered receiver in your car
There details of swapping key innards in the FAQ thread if you have a willing friend with a suitable key to test the transmitter.
Ads_Vag
Feb 23, 2011
479
Warrington
www.extremebhp.com
wheres the FAQ thread for this infomation on what i need to do?
Aug 22, 2008
3,221
cannock
ohhh i thought i was invisable ;)
tbh ime not sure how u find out if its that but ime sure someone does :), i had the same kinda problem and once the other half replaced the box it worked fine :)
Aug 22, 2008
3,221
cannock
we had a spare mate ime sure if you contact people breaking them on ebay etc they might be able to help you out just check if the central locking works first the box is at the back of eather the glove box or air bag ( whichever you have )
Ads_Vag
Feb 23, 2011
479
Warrington
www.extremebhp.com
yeah my central locking works fine... and the the led in my door flashes and if i open the boot before my doors the alarm goes off... even when i try to sync the fobs do flash 5 times but then thats it... its just the fobs that aint sync-ing with the car :S lol
PastyBoy
50
I can confirm that i too am exactly the same boat.
New batteries + five flashes = nothing
I know the inlaws Caddy has the same kind of key so may try an innards swap and recode to see if it is my key that's duff or the receiver
Ah well nothing lost (except £4 :))
Aug 22, 2008
3,221
cannock
well we have the same problem in the other gti so we are going to try a new box at the weekend so see what happens, i ll let you know :)
does your alarm go off if u dont open the car from the passenger side ?
