ok mate and no... i can open the central locking using drivers and passenger door but if i dont open them first and then go to unlock the boot the alarm goes off...
wheres the FAQ thread for this infomation on what i need to do?
you can try it with any mk2 style remote by the way to test it just make sure if you borrow a mates that he codes it back to his car after
4 - if all the above tried to no avail a friend with a same style remote is handy as they can be programmed to your car to test it and vice versa - just remember to recode it back to his/her's after
i believe that you can remove and dissasemble your original key to seperate central locking remote and key part-> so you can use someone else's remote(not the whole key). it's done in 10 seconds or less
yes just the remote secion pulls out
I gather it's just a case of finding a similar key (which you know works) popping them both into 2 parts (blade and remote) swap the blade from your non working key onto the remote bit of the working key.
Do the turn on, turn off, press 3 times, flash 5 times routine and it recodes the remote to work with your car and should lock/unlock and work correctly.
If that happens your key is fecked and you need a new one.
If that doesn't happen then your receiver is fecked and you need to start searching scrap yards for breaking ibizas with working central locking
I'm in exactly the same boat and am just trying to help!...start searching scrap yards for cards with working remote central locking
or airbag whichever you have, well as i say the other half is going to replace the box at the weekend and we do have a spare key so see what happens i will let you guys know
if i remember i will get the box out the shed tmoz to show you what it looks like
if it dont work when i try it again tomorrow, is this what im looking for on ebay? : http://cgi.ebay.co.uk/SEAT-ALHAMBRA...ps=63&clkid=8411799086253105817#ht_521wt_1139
