Update me as i wanted to put one on mine to aid flowWow , I knew these engines were strong but not that strong ! Crazy... I am
Going to have to get mine dyno’d afternoon I get these parts on, Ive resd aswell that the throttle pipe upgrade changes the noise of the air intake aswell, should be interesting to
See if it does or not , can’t complain for £160..
Only takes half hour to take the front end off lol im pro at it...or maybe because a screw dissappears each time lolI will do, last time I took the inlet manifold off , the throttle pipe was a right c*nt to take off , have to try and slide it past the fans and the engine then out from under the car
Where are you from?I originally phoned Seat up to get the cam chain done as I thought it would be similar to the timing belt at £450 as I always get the timing belt done at the dealers , then I was shocked when they quoted me 700-800£ as the parts are no where near that much.. he then told me that they would need 2 hours diagnostics to find the problem and then would drop the sump and clean it ,replace oil pick up gauze , change the oil and filter even though I done it last week and inspect the oil pump for about £300 , I took it it to one other garages and they couldn’t work out where the clicking was coming from , he said he would need to strip it down
Well since I put that engine flush stuff in , the ticking on my car hasn’t really altered so I have booked it into seat in 9 days for them to clean the oil sump , oil gauze and oil sender and have a look at the oil pump to make sure it’s all ok as they said the ticking could be caused due to oil not reaching the head properly , I asked them about the cam chain and apparently it is 700/800£ to swap it for a new one what is a joke
Hmm I’ve been told by multiply people and also seat that a block oil pick up will restrict the oil going to the head of
The engine and causes ticking , I am
Going to do my sump tomorrow and Saturday and see if it cures the problem , the ticking wasn’t half as bad until I put an engine flush in , so that makes me believe that the oil pick up has became more blocked
