Update me as i wanted to put one on mine to aid flowWow , I knew these engines were strong but not that strong ! Crazy... I am
Going to have to get mine dyno’d afternoon I get these parts on, Ive resd aswell that the throttle pipe upgrade changes the noise of the air intake aswell, should be interesting to
See if it does or not , can’t complain for £160..
Only takes half hour to take the front end off lol im pro at it...or maybe because a screw dissappears each time lolI will do, last time I took the inlet manifold off , the throttle pipe was a right c*nt to take off , have to try and slide it past the fans and the engine then out from under the car![]()
Where are you from?I originally phoned Seat up to get the cam chain done as I thought it would be similar to the timing belt at £450 as I always get the timing belt done at the dealers , then I was shocked when they quoted me 700-800£ as the parts are no where near that much.. he then told me that they would need 2 hours diagnostics to find the problem and then would drop the sump and clean it ,replace oil pick up gauze , change the oil and filter even though I done it last week and inspect the oil pump for about £300 , I took it it to one other garages and they couldn’t work out where the clicking was coming from , he said he would need to strip it down
Well since I put that engine flush stuff in , the ticking on my car hasn’t really altered so I have booked it into seat in 9 days for them to clean the oil sump , oil gauze and oil sender and have a look at the oil pump to make sure it’s all ok as they said the ticking could be caused due to oil not reaching the head properly , I asked them about the cam chain and apparently it is 700/800£ to swap it for a new one what is a joke
Hmm I’ve been told by multiply people and also seat that a block oil pick up will restrict the oil going to the head of
The engine and causes ticking , I am
Going to do my sump tomorrow and Saturday and see if it cures the problem , the ticking wasn’t half as bad until I put an engine flush in , so that makes me believe that the oil pick up has became more blocked
