Leon high and low idle issue...
ultima84
So today my Leon Cupra T (57 Plate) has shown a idle issue. I not that it has been discussed before but I can't seem to find specifics.
So if I start the car and let it idle it idles roughly between 650 to 850rpm rather then the normal stable 1200. If I then drive the car and revs under 2500 is seems to try and judder and still adjust the rpm. Once over 2500rpm it seems to drive ok except if i come off the throttle fully it seems to 'hang' then a second later slow down.
The only final difference is once it has been driven when coming to a stop it idles at 1800ish rpm. If I then sit in traffic for a time it creeps back to idling at 650 to 850 rpm.
I unplugged the sensor that is top left on top the engine when standing at the front of the car looking into the engine bay but removing it and reattching made no difference to the idle. I'm assuming this was an air sensor though half dark so hard to see exactly.
Help appreciated!
ultima84
Deffo not to mine, I've had it 3 years and never had it idle this low since the day I got it. For me its deffo got rough on idle.
When we idles between the 650 and 850 rpm it is close to stalling...to the point the lights dim etc where it is struggling to keeping the engine going so deffo not right.
ultima84
Video here
youtu.be/upvPij8t3qo ...........you will need copy and paste this to the address bar...i cant add the full address due to restrictions.
Not ideal as off phone but is u have volume up you can hear the engine juddering around while the idle sits there bouncing about.
ultima84
So the engine revs fine, when u apply the throttle there's no lack of response. The only thing if I hold constant throttle at say anything under 2500 it still tries to judder around the revs, over 2500 is fine....
Maybe air flow sensor or idle control sensor if it has one?
ultima84
I don't no anyone with it myself but in Guildford area if anyone no's of anyone with the software to plug in...
Jun 7, 2006
2,983
Norfolk, Norwich
im thinking coilpack might be showing signs of wear but im not mechanic. im sure Kev will be along soon :)
guildford i have no idea who is in that area. might be worth putting a post up in Vagcom section for help.
ultima84
I'm hoping not coil pack as it drives fine and doesn't seem to have the idle issue over 2500rpm so on motorway etc and general driving you'd never tell really,
Thanks for your help thus far!
secret.squirrel
288
Middle Earth (Wiltshire)
Anyone know if these engines have a mechanical throttle cable or is the throttle "fly-by-wire"? If its a cable, could be that the cable is dragging on the way back down causing the slow decrease from 1800rpm downwards.
As for the idle issue I'd say have a look at the air flow sensor, seems if its running fine above 2500 rpm, then its running fine on boost (assuming a boost threshold roughly around that figure). Failing that, idle sensor, failing that something to do within the ECU for which you will need VAGCOM.
Squirrel.
ultima84
CEL sorry? What's this? And don't think its got a throttle cable, think its fly by wire, and where is the MAF sensor? Only sensor I seen if on the top of the engine on the top left corner, as I say dark so no ideal for looking :(
ultima84
So I did that earlier and unplugging it made no difference, not sure if that means it was failed and stay failed when it was disconnected or if it should have gone to a default value and made it better when disconnected...
Marshall
3,256
Bonnie Scotland
This seems more like an air leak most probably by the pcv valve.
When its idling what happens if you remove the oil cap?
Does it try to stall or does it not make any difference?
ultima84
So ok just did this test.
The car is now cold so when it started it was a lot smoother idle but left it for a minute and being a bit warmer made the idling worse.
Anyway once it was idling as shown in the video linked above i removed the oil cap and there was a very slight suction (prob the wrong word) which tries to keep the cap in place. I mean a slight suction as well, noticeable but not strong.
Once the cap was off the idle rate decreased, i mean the rpm still dropped between 650 to 850 rpm but the time to get to each end of this range much slower and more laboured. When the cap was back on the car idled between the 650 to 850 range much quicker.
Marshall
3,256
Bonnie Scotland
If it makes a difference and has vacuum trying to suck the cap back on that sounds ok.
Are you running standard engine cover or an aftermarket air intake?
