LED SideLight Blubs
Moley RUFC
Up in the Lickeys........
Nov 20, 2006
1,232
Lickey,Worcs
these are the sizes, u want a 272 festoon and two 501s the same as the sidelights although as you have proberly read the two 501s dont turn off completely
Nice one. Presume the festoon style are for the number plate? How hard was it getting the internal bulb covers off?
trevstylee99
always needing help
Jul 4, 2008
51
youll need the size i gave you for the number plates and the interior 1 although the number plates wont work because of the bulb failure **** system, and you will need a 264 festoon for the boot if you want to do the boot that is. use www.autobulbsdirect.co.uk they are good and have everything you will need bar the resistor packs
trevstylee99
always needing help
Jul 4, 2008
51
the internal bulb cover isnt too bad you need a small flat bladed screwdriver to pry at the sides start at the two ends furthest away from the mirror and it should pry out, just be careful
Moley RUFC
Nov 20, 2006
1,232
Lickey,Worcs
Cool okay mate. Presume you mean the plastic moulding not the glass area. Have just tried doing this with a slim flat driver and it doesn't feel like its ever going to come off! Any other tips?
Alfredog4
76
Dominican Republic
Moley RUFC
Nov 20, 2006
1,232
Lickey,Worcs
The W5W bulb would be right i'm not sure the resistor is correct. I went for the PIAA option in the end due to concerns on connection & heat. If your a competent sparky then that route may be fine, but i'm certainly not going to start chopping wires when i can pay for a far better version that is plug & play
I'm sure it's a simple job and the guides from Mauro early on in this thread look pretty easy to carry out. It's up to you. Those W5W would however work in the front internal reading light without needing any resistor.
trevstylee99
always needing help
Jul 4, 2008
51
im a sparky but i wouldnt chop wires thats y i bought the piaa kit in the end its up to you guys in the end but unless u no for sure that the resistor is the right size u gota be careful, if you put too much resistance on the circuit the cable could start to degrade because of the heat and the cable size. rather than chopping the cables have a look for sum cable splizing kits i will try and find you a link for sum they basically allow you to connect stuff into the circuit but are removable and keeps you away from cutting the cables full stop. plus they are pennys i think.
moley the clear plastic bit is the bit that comes off you gota keep trying different angles, trust me i did it fine without leaving a mark and ive taken it off like three times now.
Moley RUFC
Nov 20, 2006
1,232
Lickey,Worcs
Yeah worked it out in the end thanks to the superb site that is http://66.196.80.202/babelfish/tran...rl=http://leon2passion.com/index.htm&.intl=us
I have translated via babelfish
Just waiting for my PIAA LED lights now, can't wait! :)
Moley RUFC
Nov 20, 2006
1,232
Lickey,Worcs
Amazingly the bulbs turned up today! Faster than stuff posted here (what does that tell you about our post). Going to fit them and take some pics
trevstylee99
always needing help
Jul 4, 2008
51
mine do it, im guna try and find an led that uses as much power as poss that should solve it, findin it however will be a problem
Moley RUFC
Nov 20, 2006
1,232
Lickey,Worcs
As promised, taken whilst just getting dark last night. Look stunning is real life with a superb blue tint to them whilst remaining pure, pure white. Make my Bluevision sidelight bulbs look like yellow indicator bulbs!
