are you going to get braided lines for them? as they were cut.
Any idea where from?
im sure i saw some on ebay a while ago.
do backdraft not do them or such companys.
europerformance sell goodridge braided hoses
The lines that you've got on your standard brakes will fit the 312mm set up.
Will you have to replace the seals around the pistons?
gutted its still not fixed mate, if i was in your postion right now i would be offically pi55ed
obviously not something small like i earlier surgested, just hope it up and running asap
i used the TT hoses as they are quite a bit longer and it would be very tight on standard hoses
Did you remove the turbo yourself mate??
weird mate
To be fair Ash, cant see anything wrong at the current moment.
Id guess the change in surface colour on that particular blade, would be where it has been machined for balancing.
So whats next if the turbo is fine?
assuming your talking brake hoses, the TT hoses are internally braided
IMO you'd just be wasting your cash buying shiny braided hoses![]()
Ah ideal. www.vwspares.co.uk sell a lot of VAG stuff at a reasonable price - will have a look then!Cheers air121005.
