Imagine the most painful sound to your ears...
cuprarsam
22
I have a LCR 2003. What is the part number for the correct springs that would fit on my car ?
Aug 26, 2008
570
West Midlands
They are shaped to fit so that the bent leg clears the pivot nut of the handbrake mech. :)
The ends of each leg are also a different shape, as are the holes on the caliper itself.
Technically it wouldn't make a big difference if they were fitted on the wrong side etc as the spring would still be trying to open out in the same way - however, the difference in the leg ends may cause it to sit at a funny angle and may affect operation.
Thanks, think I need to take them off and re-fit again D-OH!! As I am still having the same problem........
csd_19
2,279
28
Angus / Edinburgh
The springs by themselves won't cure a sticking caliper, but they do help with returning the handbrake. Have you cleaned out your calipers and checked how the handbrake levers sit when compared side to side? Sounds like you need a bit more work than just the springs I'm afraid.
Sep 4, 2012
719
Rainham essex
Will those part numbers work at TPS Lee?
Sorry but what place is tps. I usually use gsf but lately they haven't had a few things I've asked for like throttle body gasket and hockey puck and have seemed a bit reluctant to order it in and have told me to go to vw or seat.
Aug 26, 2008
570
West Midlands
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
My rear brakes were sticking and I bought the springs in hope it was just a sticking handbrake... unfortunately it was not the case...
I replaced discs and pads as it had been sticking for a while - it turned out to be the 'sliders' that sit in the carriers - apparently this is quite common. Take them out, clean them up, clean up the housing for them and make sure you grease them up before replacing.
nutter_engineer
175
I have this exact same 'mooing' noise when reversing so going to give these springs a try. there seems to be two different part numbers referenced in this thread:
N/s part no 1K0615295
O/s part no 1K0615296
7H0615295A
7H0615296
Which is the correct one for a mk1 LCR?
leon cupra r
Back in an LCR!
Nov 10, 2009
902
Barnsley
7H0615295A
7H0615296
They are supposedly the same - the 1K part number is supposed to be for Seat and I can confirm the 7H part numbers are for VW as thats where I got mine.
nutter_engineer
175
Right, got round today to try fitting these but I'm not sure I've got the right parts. The ones in the thread here show a straight edge as it comes off the coil but my ones have a kink in them. I bought them my local VW dealer but accidently gave them the Seat part numbers (1K0615295/1K0615296) so maybe its not the correct part:
just wanting to make sure before I reorder them from VW with 7H0615295A
7H0615296.
Dec 29, 2010
1,115
Mids
They should fit still give them a try, most vw rear calliper helper springs are very similar, I've just had to replace my 1 rear calliper because the springs didn't cure it fully...
Sent from my iPad using Tapatalk HD
dreago 1
Gav
Oct 21, 2011
767
East Sussex
7H0615296.
Mine are the same as this. I trust they worked?
G
