Do you mean the crank arm that the handbrake cable attaches to at the caliper? It should move when the handbrake is applied, as it is applying mechanical pressure to the piston so as to apply the handbrake. It sounds as though you have a seized handbrake mechanism on that side.
Jack up that side, apply the handbrake and see if the wheel can be rotated. Now release it, and see if there's any difference.
The rest position should be 1mm off the end stop when the handbrake lever is fully released i.e. down as far as it will go.
Have you guys that ordered through tps got trade accounts with them? I wana try and get bits through them but have no trade account ��
If you are getting brake application from the handbrake then the lever must be moving - the crank arm rotates the threaded rod up the middle of the piston to apply force to the brake pads. There is an auto-adjustment mechanism that keeps the pads very close to the disk so that the handbrake lever movement stays the same as the pads wear down.
But that lever's got to be moving!
The part numbers below dont fit and appear to be a different shape :/
N/s part no 1K0615295
O/s part no 1K0615296
Does it matter what way they are fitted?
