Then I can just put a blank over the lock and even if someone gets the blank off the lock still won't work I take it ?
ok this thread has got me thinkin
so here goes
I went out to the garage to look into this and
sat inside the car with deadlocks on you can't open the door or remove the door card to acess the central locking motor
but if you put the key in the ignition the deadlocks pop open and you're ok
so the only reason to relocate the fuse is to be able to replace it if it was to blow and lets be honest that's prety unlikely, but possable
so it's a case of " do you feel lucky"
There was a Tom Tom Sat Nav charger on the floor which they didn't take !
do you carry the spare everywhere yo go then the chances of the central locking fuse goin is unbelivably low unless you mess around moving it and it shorts out on something
