Ibiza de-locking
INSIDER
DYSLEXICS UNTIE!
Oct 17, 2006
200
no I wouldnt be happy, but also I would know that there was nothing anyone could do as it sa common sence thing for a thief to do.
how is it a common sense thing for a theif to do try sitting back and look at everyones point of view whats the point of arming people with this sort of information yes it is a weak point on a Seat but lets not shout about it and get angry at one and other
ZBOYD
Looking up at the stars!
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
If you want our urgent attention use the report post button.
That means every admin gets the message. We have full time jobs away from SCN. ;)
In my opinion its an issue SEAT should address, just like VW should too. They created the loophole, they should fix it. But they just bury their heads in the sand and deny there is a problem.
ZBOYD
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
Its not that bad if folks follow the rules. But there are a few of us, and we share the tasks. But its always better when reporting a post, to use the report post function, then we all get a message.
And the one who's got a free moment can usually deal with it a lot quicker. Rather than waiting for one single admin to read their emails or PM's
INSIDER
DYSLEXICS UNTIE!
Oct 17, 2006
200
agreed but it could be worded better imo its basically telling people how to do it and thats not right
magga
Yes they do need to address the issue, the only problem with that leon guide is that the part numbers are different so I'm not sure what parts to ask the dealer for ?
rashcupra
MV AGUSTA & 1.8T DUB MK4
Oct 15, 2006
6,517
crawley
you could do try this take the handle out by removing the cap on the inside edge of the door opposite the handle hold the handle open and using a 20torx gently unscrew the gold 20torx screw when handle lockcarrier is lose stop unscrewing and leave! take the lock carrier out and there is a long rod on the back of the carrier that sitts in the door catch when fitted if you dont ever want to use this again just simply remove it the key wont work in the door but the barrel will still be there replace carrier back in door hold in place firmly and simply tighten gold 20 torx back up and the handle will flick back into place replace the cap on inside of door and job done
magga
Then I can just put a blank over the lock and even if someone gets the blank off the lock still won't work I take it ?
What do I say to someone when I come to sell it if they ask ?
tommmineh
1.2 POWER
Feb 28, 2005
721
Sheffield/Rotherham
part numbers are the same, well i ordered the same and they look right (haven't fitted it) but they should be as the handles are identical.
If you put a blank over it, most likely the tw*t who sees it will just assume that there isn't a lock. Not the cleverest of folk these :rolleyes:
If they ask where the lock is? I'd explain to them :confused:
rashcupra
Oct 15, 2006
6,517
crawley
all o/s handle lock carriers will work anyway rear or front you could use the rear handle lock carrier with no keyhole cutout in the front just keep the standard one in a safe place then when you come to sell it swap it back
magga
Ok thanks for all your help.
Is it possible to get a lock carrier with no keyhole cutout ? It's only a 3 door so no rear doors.
Also on the guide, what is the METALDISC that her refers to ?
The worst thing about all this is.... they only nicked some fags ! :(
rashcupra
Oct 15, 2006
6,517
crawley
you could just buy the lock carrier from a rear door handle on the 5dr it will stil work fine just swap the plastic caps over from 1 with the hole to the o without a hole sop the barrel will still be there but cant be acsessed
dont worry about the "metal disc" as this has nothing to do with what you need to touch when replacing the lock carrier
magga
Ok thanks a lot :)
I ordered some parts from Seat today so hopefully they should be in soon.
I'm anxious to get it done asap cos I have a nice head unit in there and a DAB tuner and Pioneer Ipod unit too - I think they must have got disturbed and decided not to steal these. Obviously with the car in it's current state, they could easily come back and finish the job.
rashcupra
Oct 15, 2006
6,517
crawley
relocate the central locking fuse :wtf: what for? if he just replaces the lock carrier the barrel will just simply go unused
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
yep, idea being that, you can still get in the car through the boot or something and replace the fuse. If worst came to worst
rashcupra
Oct 15, 2006
6,517
crawley
if you can get in the car to get to the relocated fuse (through the boot) then the door will open from the inside if locked anyway :confused:
