DK your calipers look awesome. Going to do mine in a couple of weeks.
Cheers mate Just make sure you cover the rest of the really well, I covered all the front of mine and the overspray still got through
Sounds good that paint, do they do it in yellow? Was the paint applied with a brush? Age old question to the Op: what about the brembo logos? How did you manage to re-use them? Cheers 20vroper
Hammerite is fine to use I'd recommend spraying them rather than painting it on with a brush, you'll get a better finish. The only thing with hammerite spray is that it's very thin and you have to apply lots of thin coats to build it up to a good finish.
I've done 2 sets of brembos now with hammerite and it's fine. Although it is not an exact match for the original colour. A couple of mine.
How long are you leaving between coats, lads. Is it best to leave overnight then spray again in the morning.
Also are you rubbing down after each coat or not. Cheers.
Neil.
Sorry to hijack, DK the colour of your wheels is exactly what I am after, is it a particular paint code?
