Thanks for all the comments guys
Update
Well i managed to spend a good 12 hours in the garage yesterday
finally got finished at 1:00 this morning. Really happy with the progress yesterday.
Anyhow I'll start from the beginning......
Started off by unpacking my Shallow baffled INA sump and dropping it on to check for ARP to sump clearance, It appears i need to grind some clearances into the edge of the transmission side of the engine
So i decided to put the sump to one side and look at it again later.
I then removed the crank Girdle ready to put the crank seal housings / oil pump chain tensioner on.
I cleaned the crank seal housing up and wiped the mating surfaces clean with panel wipe, i also had to remove a bit of paint from the end before using the VW Sump sealant to seal it all up.
Oil Pump chain cable tied up out the way, housing on -
To get the larger Rear crank seal on i had to remove the upper bolts / arms from the engine stand. I dropped them off then oiled the crank in preparations for fitting the seal. I tried to fit it and it wasn't wanting to side on so i pulled it all back off and inspected the white fitting aid.... there was a sharp burr round the edge of the plastic so i busted out the knife and put a nice chamfer on it -
RMS with plastic fitting aid -
Crankshaft cleaned up and engine stand upper bolts / brackets removed -
Oiled up the crank end and the seal, fitted without any issues the second time round. For anybody doing this make sure you don't force the seal as it can be damaged very easily... all on and bolts torqued -
Both ends fitted and ready for the girdle to be fitted. As i was sealing the girdle to the block before fitting the sump i used the original (shorter) M7 bolts, i checked they would clamp the girdle before the bottomed out in the holes but a few bottomed out... so i thought about cutting the OEM bolts down and using the ones supplied with the girdle for final sump installation.
Then i found some nice heavy duty M8 washers i got from work for the exhaust to cylinder head flange.
Once i was all set-up and ready to go i cleaned the mating faces of the block & girdle with panel wipe then once dry i put a small 1.0mm bead of sealant around the block. I then placed the girdle on, lined it up and put all the ARP nuts & sump bolts in.... Torqued the Mains up to 60lb/ft and the M7 bolts to 15lb/ft.
Everything went ok so i wiped off the excess on the outside and inside.
Next up was fitting the oil pump (which turned out to be silly as i took it back off again to gain access to Cylinder 1 conrod bolts)
I then fitted the crankshaft timing belt drive pulley, with its ARP bolt lubricated with oil. In the absence of having anything to stop the crank rotating i wedged a fibreglass hammer shaft in the block and torqued the bolt up.
I couldn't find the spec sheet that came with the bolt so after searching online i found several different suggestions so i torqued it to 74lb/ft then using a breaker bar with some roll cage pipe on the end i managed to get just short of 1/4 of a turn. Put my large torque wrench on its max setting of 200lb/ft and it clicked before it tightened anymore... so it's in excess of 200lb/ft.
Next up i decided to start getting some bits on the outside of the engine.... just to clear up some of the clutter.
Water pump, manual tensioner idle roller, trigger sensor & thermostat. -
Next up i dropped the Gates cam belt on, put the OEM covers on and wanted to check the fitment for the Fluidamper, which was perfect by the way -
After all that i unpacked all the pistons & rods from there freezer bags -
Stripped the rings off piston 1 and remembered i only needed to take off the lower oil control rings to get the wrist pins out. So removed all the rings from them all and separated the rods -
Here are the tapered tool steel wrist pins i bought from IE -
Standard JE ones (parallel) -
Next i got out my accurate scales i bought from ebay and started weighing all the components -
There was half a gram difference between new wrist pins, so i weighed the pistons and matched the heaviest wrist pins with the lightest pistons and visa versa -
Then i measured the pistons with the matching wrist pins and the total weights of them were within 0.1 of a gram so i'm very happy with that
I also weighed the con rods (which were previously balance end to end by Quasar engineering in stockport)
Again with-in half a gram so good enough in my eyes.
I then cleaned up the con rods installed the bearings and torqued them up in a vice to 50lb/ft (holding the big end in the vice and not the neck of the rod) I then checked the big end clearances and they all came in at 0.04mm so well within the factory limits of new bearings... happy days
All measured -
Next up i checked the little end sizes and checked they all fitted in the pistons nicely, then using some Redline assembly lube on the pins i assembled the pistons to the rods... and then refitted the piston rings.
I already gapped the rings during the first assembly. I then went about setting the position of all the ring gaps, i used the JE instructions -
The piston & rings were then lubed up with mineral oil and using a ring compressor slotted into the oiled up bores :laugh:
I lubed up the con rod journals with redline lube and torqued the ARP rod cap bolts to 50lb/ft (cracked off 3 times each and re-torqued) all done -
Oil pump back on -
Top shots -
Really happy with yesterdays progress, next job on the list is checking over the head before refitting.
Cheers,
Graham.
