This second rebuild seems to be pretty hardcore, what sort of power are you looking for now?
Get that head in the dishwasher whilst your mrs ain't looking![]()
I just want to make sure it holds up, the turbo is rated for 500-800hp so i wan't to stretch it's legs
Oh and the cylinder head's already been in the dishwasher once..... took me longer to clean the dishwasher out than it would have to just clean the head
Nice car mate good read
Cheers bud.
Fantastic attention to detail buddy, I'm like a kid in a candy store waiting for the next update
Thanks Mate... much appreciated.
Epic build matey, look forward to seeing how things develop![]()
Thanks pal, i've been watching your mk2 thread.... a really good read
Took me 2 days to read this thread end to end and it's safe to say that my flabber is well and truly gasted at the immense amount of skill, dedication and attention to detail...
Keep up the good work buddy!
Sent from my Nexus 7 using Tapatalk
Wow thanks for the kind words.... thats some dedication to read all them pages... well done
Update time
Spent a couple of hours in the garage the last couple of days.
Lately I have been deliberating wether or not to remove the plugs from the oil galleries and clean them out with a pipe brush.
Here are the pesky ball bearings used to plug the oil galleries -
I did think about removing the ball bearings but after centre punching one with a HSS tap it didn't even mark it.... hard as hell
Anyhow i did some further inspection - I used a drill bit (by hand) through the oil holes for the lifters / camshaft journals - the drill didn't remove any unexpected carbon / coking.
Next i then plugged the holes up with Blue-tak and checked everyone of the lubrication points with compressed air..... all clear and none blocked so happy days.
I then started to clean the head up a little more than i did originally. When you look into how the camshaft journals get lubricated they use the bolt holes as a gallery..... the first time round i didn't clean them so good -
I found a 8mm drill fitted perfect so i used it (again by hand) gently turning it to remove the old oily buildup.... then cleaned each thread out using a bottle style brush -
After cleaning looking much better -
All cleaned up and ready for installation -
Next i positioned the crank just before TDC of cylinder 1 & 4.... as i was installing the head without cams there wasn't really any chance of any touching the pistons but why risk it
I then got the parts out of the spare room i was going to need for the re-assembly.
New Integrated Engineering overbore head gasket (allows bores of up to 83.5mm)..... i did think about re-using the one i originally built the engine up with as it'd never been het cycled etc.
Then i chickened out and thought for the price of the gasket i'll kick myself if it gave way -
Next job was to dig out the ARP Head stud kit and clean it up after the first installation.
Cleaned all the old lube off and put some fresh ARP Ultra-Torque Assembly Lubricant on the threads.
Installed by hand -
Unpacked the head gasket, cleaned it up and dropped it on, taking care about the orientation -
Hopefully the last time i'll see the pistons
I then carefully lifted the head onto the block.... locating in the pins -
I then lubricated the bottom edge of the ARP nuts and dropped them on. I then followed the instructions and hand tightened all the nuts in sequence, followed by torquing them to 20,40,60 then finally 80ft/lbs.
Instructions for reference -
Shot all torqued down showing the ARP nuts -
Next out of the spare room came some more IE goodies
IE Billet Adjustable Cam Pulley, EKAGrip washer, ARP Bolt -
Next up unpacked my Integrated Engineering IECVA1's... these are the version 1's that i bought from Clay @ CTS ages ago -
The camshafts claim an extra 100bhp on GT30 sized turbo's and after comparing them to original cams i can quite believe it !!
Comparison of Exhaust Cams -
Comparison of Inlet Cams -
By the looks of the cams IE really went to town with the design of these, nice radiuses on the noses... plenty of duration.... looks like it'll be easier on the valve train than the peaky OEM cams.
Assembly time, put the Camshaft oil seal on, then the EKAGrip disc on - served with lashings of loctite style stuff. Torqued the bolt to 55ft/lbs if i can remember right (what ever the instructions said for the ARP bolt) -
Same for the inlet cam, seal on then trigger window - the OEM torque level was really low so i also loctited the bolt in, and torqued to OEM spec -
Placed them in the head to check fitment (without Lifters).... all good on the exhaust cam.
BUT then i ran into a problem with the Inlet camshaft.
The inlet cam didn't want to seat fully into the head, it was awfully tight to rotate too.... hhhmm time to investigate. Dropped the stock inlet back in - that was free as a a bird.
I then busted out the verniers and started checking the journals of the IE cams... all perfect strange i thought but good news either way.
After much head scratching i thought ahhh maybe the width of the thrust cut out is too tight (last journal next to sprockets) again measured up all good.
I then found then last journal (thrust journal) on the cylinder head had burrs on it... Strange i checker all the journals very closely and it wasn't there before. That meant when i was turning the IE cam in the head it had burred the journal, but why all the sizes seamed perfect.
So i then concentrated on this journal and found the problem. The radiuses on the inlet camshaft were all not cut correctly, they are not deep enough.
For people who don't realise all changes in diameter should be radiused - the reason is a sharp 90 degree cut would create a weak point that a fracture could start from.
All of the journals of the cylinder head are much narrower than the cutout in the camshaft so the only one that was causing an issue was the rear Thrust journal as its wider than the rest (to stop the camshaft floating in and out)
I placed a flat edge along the journal and slid it along until it touched the rounded edge to show what i found -
When i inspected the journal in the head i could see the cam had been rubbing on the edge of it thus creating the burr. Hard to photograph with an iPhone but its the last journal (the one with the oil hole... not the one with the groove thats the cam seal seat)
I decided the easiest way out of this was to chamfer the journal in the head to give clearance for the radius. Machining the camshaft would have been very difficult as it would have been very very hard.
I then decided to put plenty of paper in the head to collect the swarf -
I then put a 1.0mm chamfer on the journal, both sides by hand, the aluminium is very soft so used a sharp knife and a needle file... again really hard to photo -
I did this a few times, taking off a bit at a time until the cam until it span freely... happy days.
This shows why you should never throw parts into an engine without checking and double checking stuff. Even very high class manufacturers like Integrated Engineering can have mistakes when having stuff made.
Most people just drop in cams but i think they should remove the lifter and check they spin freely with the caps installed.
Next up i cleaned up all the camshaft caps and torqued them down to OEM spec - they still span nice and freely.
I then unpacked the new hydraulic lifters and cleaned them up -
Removed the cam caps / camshafts in preparation for the final assembly -
Installed the lifters with plenty of redline lube on them -
I then put the crank round to TDC no 1 on the timing mark on the pulley and dropped the camshafts / VVC unit in with the new OEM timing chain -
Managed to get the timing right first time.... thinking it was luck more than judgement.
16 Rollers between camshaft marks
I also installed a new VVT gasket and half moon seal. A tiny bit of VW sealant on the areas that needed it (keeping away from the oil supply hole)
I then torqued down the cam caps in the correct order - Caps 2 & 4 first on each cam then 6 then 1 and finally 3. Cap 6 also got sealant on the faces.
Dropped in -
All bolted up and torqued
Next up, i popped the Gates kevlar belt on with the IE manual tensioner. I do have a TFSI tensioner coming from AL@PagParts which i'm gonna try out.
I'm planning on doing lots of testing with different set-ups - i'll report back on belt tensions once they arrive.
Next i cleaned up the rocker cover gaskets and fitted the covers to the inlet cams -
I cleaned up the NA rocker cover i bought a while ago and dropped it on -
Probably gonna paint it wrinkle black but i just want to get the motor all sealed up to stop any dirt getting into it.
And finally the money shot
Really happy now, just the oil filter housing to clean up then install the ancillaries.... oh and the sump.
Thanks for reading and any comments,
Graham.
