Thanks for all the positive comments, there much appreciated
Nice!! Graham - are you tempted to top mount the gear shifter like I did with
Ibiza? I found that the added heat through the exhaust just causes mahem and melts the linkage. I ended up having to replace them!
Hi Joe, i wasn't going to run them above the tunnel as i wanted to run the standard centre console.... although i have been looking at the SQS shifter, i'd love one but they are mega money for what they do. Maybe in the future i'll get one, like you say probably after i melt the oem cables lol
This is without doubt the best/most interesting thread I have read I would love to be able to do all of this!
I attempted to tidy the scuttle area a bit and moved the contents of this to free up a bit of space for a catch can:
Apologies if that was extremely patronising! haha
Thanks for comments and the info, not patronising at all
i was already thinking of pulling it back to mount in the scuttle area / tray as it might get a bit melty from my side mounted turbo.
Overdue Update
Well i have let two months slip by without really doing more than a few hours work in the garage. As always things like family and only getting home for 1 night some weeks doesn't
help.... anyhow enough of the excuses, as i have a few days garage time pass from the missus for good behaviour.
Since the last update i put the remaining door accessory panels in and installed the windows / motors and window seals.
I can't really bond the windscreens in yet as the chassis is on dollys at the moment and once i lower onto its wheels the chassis will flex and could crack the screen.
I've ordered up some powerflex black series bushes for the front suspension, i went with the rose joint bearing for the wishbones
So my priorities are as follows -
Strip all the suspension / hubs / subframes down (remove all bearings / bushes) - in preparation for shot blasting and powder coating.
To do this i needed to get the subframe down from the garage rafters as i put it up there ages ago to save space.
To get the subframe down i had to push the car out of the garage
Picks in the daylight -
It was nice to see it in the flesh outside of the garage... looks like its taking shape now
So lifted the subframe down, whilst nearly pulling my back out -
This is one that i bought from a TT so its got a quick steering rack installed
While i was on i decided to bring the engine stand down and build it back up -
I have already decided to rebuild the engine to replace the gudgeon pins in the pistons to the tool steel versions i bought last year..... so i decided to get the ball running on the engine so it can be finished off and installed.
There is an engine under there, i think
Once i cleared all the crap off the engine i manhandled the engine gearbox out of it's hideehole and started to split it ready for mounting on the engine stand.
After trying for 30mins struggling to separate the engine and gearbox i remembered there was a bolt that went the other way under the transfer box. Once i removed that it came apart much easier :roll eyes:
Shot of the Clutchmasters FX400 -
Pressure plate off showing flywheel clamping bolts with steel ring to spread the clamping load -
My mate then dropped my engine hoist back round so i lifted the engine back on its stand -
I then got a bit carried away with the strip down -
Pulled the head off it !!!!!!
Unfortunately the engine has has sat in the garage for so long it's gone rusty again, only on one side which is weird. I will have to redo the paint work
Rusty rusty -
So i then span it round and pulled the sump off -
At least nothings rusty on the inside
Then i decided to drop out the pistons & rods -
Not bad for a few hours work.
I'm off to machine mart this morning to buy a DTI (clock gauge) to check the crankshaft isn't bent. Not the end of the world if it is mind as i have a spare TDI 95.5mm crank.
Thanks for reading and any comments. Hopefully i'll update tonight or tomorrow.
Graham.
