Going to build a race 1m
Manic172
Dec 4, 2018
1,447
1,580
Hemel hempstead
www.seatcupra.net
I have now been making a few fuel line and sort of got the hang of of it. It seams easy but it's fidderly too.
So mark out your pipe and cut with either a grinder or big metal cutters
Put tape areound befor you cut it helps to stop it from slaying out
I have plastic coated braided hose. So I need to cut that back about 6-8mm
The fittings are for teflon hose .
Make sure you have the right fittings for the type of hise your using. . The teflon ones have this olive to seal against the tubing
so started off take your tape off and slide the nut over the tube . Then open out the steel braiding.
then slide the olive on down to the shoulder of it
using the special tool to open out the tubing to make sure the fitting slides in is this special tool
you can get all differnt ends for different size and fittings then slide the rest of the fitting in to the tube
all the way to the end
then I bought these ally clamps to not scratch the fittings that fit on to the vice
Also these ally adjustable spanners too also so they don't scratch. And then tighten
Manic172
Dec 4, 2018
1,447
1,580
Hemel hempstead
www.seatcupra.net
A big thank you to fuelabs the the 2 low pressure intank pumps
an to torques for the 2 pick up pipes that go on to the tank and bulk head connections to suit
So remove the old fittings
and screw in the new ones
the push the pipe on to the barbed end and on to the pump. Do this for both. And secure with the jubilee clips supplied
Just need to wire in. I have drilled and fitted a electrical gland for the wire to go threw.
When wired in I will refit the foam insert. And screw the top down..... might have to buy some fancy screws for that..🤔 off to eBay
  • Love
Reactions: nd-photo.nl
Manic172
Dec 4, 2018
1,447
1,580
Hemel hempstead
www.seatcupra.net
Little mock up of the swirl pot. An8 outlet at the bottom. The two an2 on the side are the feeds from the 2 low pressure pumps in the tank. The fitting in the top in the return from the engine with a 1 way valve. A tee so it can go back in to the swirl pot. If not it over flows back to the tank...... hopefully
Manic172
Dec 4, 2018
1,447
1,580
Hemel hempstead
www.seatcupra.net
Morning all. Right bits of progress finally welding the steering coloum. And lengthened the coloum.
Just need to do a bend or 2 just to help angle it down towards me.
Next fuel cell is now hopefully plumed in and electrics done. The rest of the fuel set up (incar not engine yet) it now laied out and bolted down into nutserts. I just need to start making fuel lines. That's a job for tonight
But it's all slowly getting there now. Still loads and loads todo but can also see progress. Hopefully get me meet some of you lot at super touring power in June.
More updates soon
Nathan penney
Active member
Jul 8, 2017
760
922
Liverpool
Me and my lad are still hoping to get down to Brands for the Super touring event. Can’t wait to see this car of yours.
I have to be a bit choosy over weekends in June.
We’re going to Le Mans, it’s Oulton Park BTCC which is the nearest to us, Tatton park classic show and this at Brands, all weekends in June. May need to sweeten the missus up. :ROFLMAO:
But we defo want to get to Brands.
Will be a long day but I’ve done it before for the BTCC.
Reactions: Manic172
Manic172
Dec 4, 2018
1,447
1,580
Hemel hempstead
www.seatcupra.net
Afternoon all. I have been playing about and mounted the dash pod unit
it lines up quite nicely threw the steering wheel and the column we made .
Next up is the rain light for motorsport. I looked at in the rear window.. or using the original fog lights etc. But found this msa spec light that was nearly the same size as the rear seat badge recess. So I was going to mount it to the boot lid.. but then opted to make a bracket then mount it near on flush.
With the decision of staying hydraulic power steering but not using the original pump. As using any thing that is driven from the engine it takes power away from the engine. And I found some figuring out that a power steering pump using more power than an electrical power steering pump. So with that I got an astra h pump unit. But thought it will be working hard. So fitted another cooler to the front on top of the inter cooler
Only a little 7 row jobbie but it will help to cool the fluid.... hopefully
