Gearbox oil change
Bigjohn84
Intagram / johnyoung84
May 5, 2015
2,330
See you should have just asked for the workshop manual lol I would have gave you it haha
Bigjohn84
May 5, 2015
2,330
Don't go paying stupid amounts of money for gearbox oil, that link Dosnt work.
Bigjohn84
May 5, 2015
2,330
If u race up the gears go for the better oil, totally up to you, I wouldn't waist my money
Bigjohn84
May 5, 2015
2,330
Each to there own mate, I'm not gonna say as other people will say different so as long as you get the 75/90 you will be fine, what make and price is up to you.
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
523
Swindon
Ok cheers, just went with it in the end.
UPDATE
***Do not use the above oil for the LC as just found after changing mine 2nd and 3rd are no longer as smooth when changing up ''notchy'', got some advise from oil sellers and was advised that although this oil is ok for my gearbox it is just ok as they have had reports some people use that in in those gearbox, but it can make the gear changes too stiff and put unnecessary strain on the box. :( ***
Will be changing it out with genuine VW stuff this weekend :(
516
Shrewsbury
Hey
So im gonna do the oil change this weekend, is it about 2.5litres of oil? cuz i only have 2 jack stands/trolly jack, i wouldnt be able to to fill it when its level?
Could i jus guestimate it at 2.5l? As when the front end is jacked up, it would be reclined at an angle.
Bigjohn84
May 5, 2015
2,330
If ur on about changing the gear oil then keep putting the oil in till it drips out the fill hole then you will be fine,
516
Shrewsbury
Any solutions for non shimable gearbox's (FML)
i changed the oil and it does feel abit smoother. still ''notchy'' tho.
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
523
Swindon
All Done, Thanks for all the help everyone :happy:
Thanks for the heads up on special M16 x 58 mm Spline to be able to open drain and fill bolts :D
Malice19
.:Cupra 4 The Win:.
Mar 16, 2006
523
Swindon
Which gearbox oil did you use as just found after changing mine 2nd and 3rd are no longer as smooth when changing up ''notchy''.
