This bites
Yeh had my new dv for past month now. Everything was fine, till i started to get a few issue such as turbo lag, the dv sound soft and loud, follwed by the turbo spolling up. Plus the Overboost limt exceeded.
So that past week i been hunting around the engine. ive checked the dv and done pen test. it was fine. then carried on looking. i then went back to check the dv again.
Removed it. ive noticed some oil around the dv out (compresser1).
Took it inside cleaned it. i then gave puff of air in and i could hear some thing hissing. I then filled one of the inlet with water and then began to blow. water began to drizzle from the side of it. Screwed of the pipe, cleaned all the oil/dirt deposit, then screwed it back and used some pliers to tighten . Improved it but still leaking.
![Banghead :banghead: :banghead:](/forums/styles/seatcupra/oldforumsmileys/banghead.gif)
i know when its on the car it will leak more as its running at higher pressure compared to my mouth
Ive refitted my standard dv. but i know for a fact this will not last.
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Have to get in touch with forge and hope they could
help me again.
