Preload is the pressure of when the actuator starts to open? Or is the static pressure? Im not clued up on it mate i got awsome gti to fit and set mine up
thats high boost... and you want more?
got rods?
you will need them
Jesus... Read the post. Am asking if i need to adjust the actuator for the higher boost the cars running from the map. Since am now getting wastegate chatter. I dont want anymore boost.
Could this be because i need to set the actuator up for higher boost?
nice attitude
I suggest YOU Read your own post
Hardly unambiguous is it.....![]()
Jesus... Read the post. Am asking if i need to adjust the actuator for the higher boost the nning from the map. Since am now getting wastegate chatter. I dont want anymore boost.
You got a proper attitude problem there was nothing wrong with his reply was a jokey reply imo. You come ona forum asking advice which people are giving. Chill out or do one
What way was his reply jokey or helpfull? Telling me 'you will need new rods'
Anyway this is way of topic...
Lets get back to it. If someone can help.
running that sort of boost you will need rods. Ibizacupra is a respected tuner on here and knows these engines through and through. he was simply trying to make you aware that running any more boost on the standard rods your more than likely to throw a rod through the block.
if you was looking to run higher boost and wasn't told about this you would probably come back saying why didn't anyone warn you!
This is getting silly now. I see now my first comment was worded abit wrong. And to clear this up i am NOT looking to get higher boost. What am trying to say is because my cars running higher boost after the map am staring to get wastegate chatter. So i was wondering how to adjust the actuator to stop this.
chatter is not actuator dude
if you fit an actuator which is stiffer than the std one you will likely end up with a larger spike of boost, as the pid control will loose control of requested boost on spool.. Boost onset will shoot past resulting in high boost, high torque spike which is Risking your Engines rods
Your car has a boost request on normal mapping.. messing with a non std actuator without mapping tailored to suit risks damage.
Your noise, such as its been described thus far is wastegate chatter, which is not actuator related in reality.
Is it a flutter on gear changes?
The actuator rod needed adjusted, Just as i thought.
Chatter mabie wasn't the best word to describe it but borgwarner call it "boost droop" basically the boost going flat at hight revs. Instead of the air going through the turbo it was creeping round thought the wastegate higher up the revs and giving me the chatter noise. Just a tiny bit preload on the actuator and sorted.
actuator as in wastegate actuator is Nothing to do with sound...
