flip key info thread
tdicuprasimon
hey hey
Got myself a 434mhz skoda 3 button key, swapped the transponder, got a blank cut and did the ingnition on and lock trick and it all works. Great stuff thanks for the guide.
Simon
jake_h
95
Key Fob Programming
VW/ Audi/ Seat/ Skoda
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second key
3. Using the remote control press the Unlock button once, and the horn will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding procedure. The remote control will now be programmed.
Note: When performing programming on additional remotes the procedure is exactly the same, except you press the unlock button 2, 3 or 4 times for different remote.
For example: If programming 2 remotes press the unlock button twice with a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote control.
hope this helps....got this of a guy who i bought a key off, works a treat
MarkTDISport
do you need to have the blank cut? i've did everything apart from this and my car still hasn't made the noise no matter how many times i press it. has anybody any advice? cheers
MarkTDISport
i used blue tac to make sure that the transponder sat in place, would this affect the process?
Red Panda
368
Not telling
I don't know.
I got a 3 button flip key 'HLO 1JO 959 753 DA' and it works a treat on my '05 FR - the boot button works too. The guy I got mine from is selling brand new 3 button remotes on ebay minus key blade and transponder for 20 quid. Bargain! compared to a main stealer.
MarkTDISport
cannot understand why i cannot get mine working, my original key is 434 mhz and the new flip i bought is 434 mhz. transferred the old transponder from the none remote key and carried out the method posted a few pages ago. still no joy even taking the blue tac out and switching the ends around on the transponder. has anybody any advice?
Jan 11, 2005
680
Barnsley
What isn't working? Can you start the car? That's what the transponder is for, it has nothing to do with the central locking. What's the part no of the key fob?
MarkTDISport
I cant seem to programme the remote to the car, i thought by using the transponder from the non remote key that would enable me to pair the new key to the car. but obviously not if the transponder is used to start the car.the part number on the new key is 50w 1j0 959 753 ct, 434mhz, 5fa 009 259-55. the part number from my current remote key is 434 mhz, 008444, 0878, 5fa 008548.
MarkTDISport
is their a better key i should be buying to fit with my car? the seller has offered to take the key back lucky enough, but i would still like this mod. how should i go about it?
Jan 11, 2005
680
Barnsley
AH suffix works using the 2 key method.
N suffix doesn't. If I get chance over the next few days I'll have a play with the N suffix key to see if there is a different method of programming it
MarkTDISport
AH suffix and N suffix ?!? lol
i sent the key back to the seller as he was also giving me advice but to no avail.
darkhorse could you recommend the best key to buy on ebay please? cheers for your help.
Nov 15, 2010
1,364
Harrogate, England
I really want to change to a flip key but at the moment the key that came with the car doesnt work, it starts the car but it doesnt unlock the doors with the remote, i guess it isnt programmed
Joe_3490
404
hmm if its original one it may be the battery is flat. try changing it first
fackers
ive just bought a 3 button flip key from Ebay, and my current key only has 2 buttons.. with this new 3 button and the boot popper mechanism bought from TPS (vag parts) would the boot popper work off the key?
Joe_3490
404
i have a three button one and if you hold the boot button for a second it will unlock the boot and boot alone and when you close the boot it relocks itsself
