Just coded my 3 button flip key to my cupra. Cost breakdown was £5.00 for the remote unit which looks like new, £5.20 for the uncut ket & transponder assembly and £5.00 to cut it. Total cost of £15.20
I used vag k+can commander to retrieve the skc pin number (took 5 mins) and then vagcom to add it to the immobiliser (2 mins). Timpsons couldn't cut the cheap ebay key because their machine wouldn't clamp it square but another key cutting place did it without a problem
EDIT: Forgot to say that if the boot release button doesn't work, it can be enabled in vagcom. I forget what you have to do but if you can get hold of vcds the label tags tell you what's what as you go through the basic settings in the instrument control module
