seebul
swapping transponder out of your old key into the new will be fine, just dont break it![]()
Thanks for the quick reply! Hope to get my new key delivered this week.
i did have slight troubles when i first got mine, but now its no troubles, get a small ish flat screw driver and put it in the crease down the side is better if u start on the edge were the other side of the key slots into and ask it politely to come appartor not so politly...
I only got one key with my FR so i'm bidding on a flip key from ebay (blank blade) will i be able to programme this to my car as after reading this thread i'm unsure if i can programme it to my car? As most of you guys have removed the transponder from your spare key and stuck it in the flip one?
Hope you can help
Neil
If i buy one off ebay and get the blade cut do i have to get SEAT to programme the key to work with my car?
you need the same blade as the original and u need a blank immob chip and at least 1 working immob chip in a different key to lock the new immob chip to your car (you might not be able to start the car tho) as i had to have mine put on with a computer. the guy who i used lives in london and he would be bale to sort you out if you live near.![]()
I'm just posting this here as I also did on the Leon forum, but this thread is a bit more active:
OK, I'm now getting a little confused with this thread. Basically I have the two original keys and a new third one off fleabay. The fleabay one has the same model code number down the side of the key as my original one although the innards of the remote bit is slightly different so I'm hoping it should be ok in terms of frequency - I haven't got the blade cut yet or the immob chip done yet.
At this stage I'm only trying to get the remote central locking programmed.
My initial remote key is broken (the chip inside it is damaged).
Question number 1 - will this method work if the original remote key is broken?
Question number 2 - with the new key it doesn't matter that the blade and immob chip are different, right?
Question number 3 - so you take the original non-remote key and use that one in the ignition and turn it to on (i.e. lights on but not engine running). You used your original remote key to lock the door. The third key you just hold near the car. Now the pressing of the buttons (i.e. both step 3 and step 4 in the original process) - is this on the original remote or the new remote?
Have a feeling that basically the answer to question 1 is yes, 2 is it doesn't matter and 3?? Please can you help me figure out why it ain't working for me!!
And all this is true if I'm just trying to program the remote central locking feature (which as far as I understood didn't need the blade to be in the car).
you can program a remote with no blade but you need 2 blades to do it one in the ignition (oringinal working key), and one to turn the door lock, as long as you have this, you can program up to 10 remotes (IIRC)
