Where is everybody getting the blades cut? I went to Timpsons and they said they couldn't do it :S
mine was done at timpsons. you need to find there bigger stores that do laser cutting
my blade wasnt laser cut, they used like a mini-pedistal driller
After going to about 4 different Timpsons and getting the 'can't do it' response, I thought sod it and went to VW, and oly got charged a tenner
But now i can't get the damn Skoda sticker out![]()
I tried to set it to a zero but it wouldn't let me. I haven't done a channel 00 read and save as I'm a bit worried about what other settings that will wipe!
what version of vag com are you using?
4.09 (or whatever it is) registered with a flebay cable.
yep easy to change the blade, just push out the small roll pin swap the blades then put the roll pin back in
Is it 433 or 434 for a 98 alhambra...
