Cheers Bob.
Is it still likely to be the water pump regardless of the fact that it's not gone over 90 deg since? Only did it once in that traffic jam, stayed a steady 90 after that, and not once has it gone above since, not even at a steady 90+ on my own private stretch of M5?? Just a bit concerned as i've not mentioned any possible water pump problems b ut i did stress the fans not coming on low speed.
Do you still think i have the low speed fan
problem too??
Is there any chance that a broken water pump impellor could cause a rattle on start up occasionally? I've put that down to a slow filling tappet, which is the lead i gave them when i booked it in........
