DPJ's GTRS Eliminator Install and Development
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Bonjour (just back from a long weekend).
Logs look a good starting point, rather laggy though like everyone else's said - but you've got stuff to try. N75 made me laugh, actually (100, 100, 100, 100, 100, 40, 40, 40, 40 :D ). A/F looks alright (I think). I'm with Marts, I think the dp will sort it (at least improve it).
You've just mentioned LCR pipework, but you've let your RHS Inlet manifold go :confused:
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
ça va, Monsieur Feel?
Yes A/F's not bad at all.
Sorting the DP means making superbracket for the shifter cables. (another job).
The LCR FMIC will run right to left, not just left to right ;)
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Ah, but try saying it in French, mon ami? That did my head in that did...
Wise to avoid the coil pack(s)
Nov 2, 2004
9,335
South Wales
2.5" cat'd downpipe and SMIC vs. 3" cat-less downpipe and decent FMIC is gonna make those logs look a whole lot different.
Dont touch the settings dave, i wanna see what the difference the extra hardware makes on the logs. :D
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Map sensor boss is on the central pipe above.
Aquamist - give me a chance, next thing you'll be telling me that the drum brakes on the back aren't up to the job! :D There'll be room for a short alloy pipe just before the TB (at a later date) if it fits together the way I think it will.
Ruddmeister
Everything in Moderation
Jun 23, 2003
8,218
Weston-super-Mare
en.wikipedia.org
I've only got the set of logs that included 196 g/s and a 60-100 4th log Steve. When it's sorted, I will take it to JBS for a RR run if there's no group day going.
I think that would be a good idea taking it to a decent RR and get a run so you can spot any problems or areas for improvement. Always Interesting seeing and hearing your car at full chat but stood still.
I look forward to seeing the graphs....once you have seen a graph for one remapped LC you've seem them all....be interesting to see the shape / delivery and of course numbers for your creation.
The end must seem pretty close now.......then you can plan your next phase of mod's :cartman:
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Thought it would be, just checking :D
And on the Aquamist: :pullinyerlegmate:
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I did the long commute to work in it today, no issues. :) I get the odd pop in the exhaust when I back off, that I never got on Revo Stage 2. When you keep the revs 4k+ through the gears, it seems blisteringly fast .
Strangely, I'm getting interference on the radio now, what can I have disturbed. :confused:
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
earth/grounding issue?
pops are on overfuel on overrun, speak to kev, the map may be a tad on the safe side to get you going???
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Cheers Saul. I suppose several weeks leaning on the top of the rocker cover could have shifted something. I've got some wire & connectors tucked away that I bought ages ago to make a grounding kit. I'll pop it on when I'm doing the FMIC this weekend. Yes, I'll mention over-run to Kev. :)
Nov 2, 2004
9,335
South Wales
Can someone explain how you work out the A/F from the values on the logs? Not used wideband before as mine is normally done on MAF/Injector time etc...
