Bonjour (just back from a long weekend).
Logs look a good starting point, rather laggy though like everyone else's said - but you've got stuff to try. N75 made me laugh, actually (100, 100, 100, 100, 100, 40, 40, 40, 40 :D ). A/F looks alright (I think). I'm with Marts, I think the dp will sort it (at least improve it).
You've just mentioned LCR pipework, but you've let your RHS Inlet manifold go :confused:
ça va, Monsieur Feel?
Yes A/F's not bad at all.
Sorting the DP means making superbracket for the shifter cables. (another job).
The LCR FMIC will run right to left, not just left to right ;)
Ah, but try saying it in French, mon ami? That did my head in that did...
Wise to avoid the coil pack(s)
2.5" cat'd downpipe and SMIC vs. 3" cat-less downpipe and decent FMIC is gonna make those logs look a whole lot different.
Dont touch the settings dave, i wanna see what the difference the extra hardware makes on the logs. :D
I promise I'll keep it scientific, Phil.
Map sensor boss is on the central pipe above.
Aquamist - give me a chance, next thing you'll be telling me that the drum brakes on the back aren't up to the job! :D There'll be room for a short alloy pipe just before the TB (at a later date) if it fits together the way I think it will.
I've only got the set of logs that included 196 g/s and a 60-100 4th log Steve. When it's sorted, I will take it to JBS for a RR run if there's no group day going.
I think that would be a good idea taking it to a decent RR and get a run so you can spot any problems or areas for improvement. Always Interesting seeing and hearing your car at full chat but stood still.
I look forward to seeing the graphs....once you have seen a graph for one remapped LC you've seem them all....be interesting to see the shape / delivery and of course numbers for your creation.
The end must seem pretty close now.......then you can plan your next phase of mod's :cartman:
Thought it would be, just checking :D
And on the Aquamist: :pullinyerlegmate:
I did the long commute to work in it today, no issues. :) I get the odd pop in the exhaust when I back off, that I never got on Revo Stage 2. When you keep the revs 4k+ through the gears, it seems blisteringly fast .
Strangely, I'm getting interference on the radio now, what can I have disturbed. :confused:
earth/grounding issue?
pops are on overfuel on overrun, speak to kev, the map may be a tad on the safe side to get you going???
Cheers Saul. I suppose several weeks leaning on the top of the rocker cover could have shifted something. I've got some wire & connectors tucked away that I bought ages ago to make a grounding kit. I'll pop it on when I'm doing the FMIC this weekend. Yes, I'll mention over-run to Kev. :)
Can someone explain how you work out the A/F from the values on the logs? Not used wideband before as mine is normally done on MAF/Injector time etc...
