The latter is very tempting! :D
I've blown hot and cold about fitting a later bumper for a long time. :shrug:
Short term, I can cut vent slots across the remaining front valance (that's behind the front skirt), then fit a section underneath to divert air from the long wide slot in the front skirt.
Or one of those scoops that trains used to use for picking water up from the track mounted water containers, like a reverse wing just under the bumper.
Surely it would be cheaper, easier and better to just fit a normal facelift bumper :) No rubbing strips on the bumper then either :)
Been away for a week dave so i've missed this. Amazing the drop in intake temps now, dropped by half! And it shows on the CF's as well.
3" decat DP and some serious SPS3 tweaking is gonna have some serious effect especially as your only just tickling the turbo and not gettin and CF's now.
Sorted a fuel pump yet?
I thought you were away , Phil. :)
After I saw what happened to Craig's, I got straight on and ordered a Walbro inline. It's winging its way across the pond now.
Today I got an early start on the 250 mile round trip to Pipewerx for Ian Birch to build me a 3" DP to fit to my 100 cell race cat / Blueflame Dual System. (Ian had custom built the turbo-back system on the car when he was at BF).
It was great to see Ian again and have a chat, its a lovely setup in country surroundings, nothing like BF. :rolleyes: His next 4 wheel project sounds as exciting as previous ones. ;)
My new DP is a lovely piece of work. My front Lambda wouldn't come out of the old 2.5" DP, but Ian had a used one to hand.
I'd recommend that anyone who needs an exhaust, standard or custom give Pipewerx a try.
The car seemed to pull better on the way home. Here are the logs I did early this evening.
Still LB9 T5. Air temp 23.5 degrees.
Code:
Friday	3	August	2007	18:04:05
06A 906 032 HN		1.8L R4/5VT         0002
Group A:	'003			Group B:	'020
Idle speed	Air mass in	Throt Angle	Ignit Angle	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
 /min	 g/s	%	 °BTDC	 CF	 CF	 CF	 CF
3000	56.92	100	26.3	0	0	0	0
3160	65.11	100	24	0	0	0	0
3400	75.72	100	23.3	0	0	0	3
3680	92.94	100	21	0	0	0	3
4040	114.44	100	15	0	0	0	2.3
4400	142.56	100	12.8	0	0	0	2.3
4840	162.31	100	6.8	0	0	0	2.3
5240	175.94	100	7.5	0	0	0	2.3
5560	178.44	100	12	0	0	0	1.5
5880	189.03	100	10.5	0	0	0	1.5
6200	202.44	100	9.8	0	0	0	1.5
6480	203.17	100	12.8	0	0	0	0.8
Code:
Friday	3	August	2007	18:06:53
Group A:	'115				Group B:	'031
Engine Speed	Engine Load	Spec. Boost	Actual Boost		Lambda Factor	Lambda Factor
 /min	%	 mbar	 mbar	STAMP
3120	103	1980	1420	34.12	0.899	0.906
3280	109.8	2040	1520	34.83	0.852	0.844
3520	121.1	2100	1640	35.54	0.821	0.828
3920	139.1	2210	1850	36.24	0.805	0.821
4280	157.9	2270	2100	36.95	0.789	0.805
4680	176.7	2260	2290	37.76	0.805	0.805
5120	178.2	2240	2410	38.56	0.789	0.805
5440	167.7	2240	2270	39.26	0.805	0.805
5880	166.2	2230	2290	39.96	0.797	0.805
6200	169.9	2240	2460	40.68	0.797	0.805
6480	158.6	2260	2190	41.48	0.789	0.805
Code:
Friday	3	August	2007	18:09:40
Group A:	'118			Group B:	'032
Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost	Idle O2 Adapt	Run O2 Adapt
 /min	°C	%	 mbar	%	%
3120	30	100	1210	1.7	4.7
3360	29	100	1430	1.7	4.7
3600	28	100	1600	1.7	4.7
3960	27	100	1790	1.7	4.7
4320	27	65.5	2120	1.7	4.7
4720	28	57.6	2340	1.7	4.7
5200	29	45.1	2340	1.7	4.7
5520	30	42.4	2160	1.7	4.7
5880	31	40	2090	1.7	4.7
6200	33	54.1	2280	1.7	4.7
6520	34	47.8	2320	1.7	4.7
Strange the way N75 duty cycle dips just below 6k revs, taking boost with it - then it comes back :shrug:
My Walbro inline pump arrived from USRT in the states today, 7 days from order. :funk:
I have my chores to do tomorrow (Mrs DPJ's and youngest daughter's cars to service) before I can play out.
