Crank the boost up dave. Lots! Logs look pretty good to me still.
If you had to guess the power now compared to the k03s what you reckon its pulling?
Those logs look pretty good. Fueling is running nice and rich keeping egt's down. Nice boost hold post 6000 rpm. I would expect a little higher mass air readings as i achieve a little higher 208g/s measured 48hrs ago at slightly less boost. :shrug:
I recon your running aprox 280 bhp.:funk:
I'm well jelous:drool:
HB7 T7 outside temps 22 degrees.
Code:
Saturday	4	August	2007	17:56:57
06A 906 032 HN		1.8L R4/5VT         0002
Group A:	'003			Group B:	'020
Idle speed	Air mass in	Throt Angle	Ignit Angle	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
 /min	 g/s	%	 °BTDC	 CF	 CF	 CF	 CF
2480	42.36	100	27.8	0	0	0	0.8
2640	49.03	100	24.8	0	0	0	3.8
2760	53.28	100	24	0	3	3	3.8
2920	59.03	100	21	0	3	6	6.8
3080	62.33	100	15.8	0	3	6	6.8
3240	69.53	100	23.3	0	3	6	6.8
3400	77.94	100	20.3	0	3	6	6
3600	89.56	100	15.8	0	2.3	5.3	6
3840	107.36	100	14.3	0	2.3	5.3	6
4080	127.47	100	12	0	2.3	5.3	5.3
4320	141.06	100	10.5	0	2.3	5.3	5.3
4560	156.67	100	8.3	0	2.3	5.3	5.3
4840	170.5	100	6.8	3	2.3	5.3	4.5
5080	176.78	100	6.8	3	2.3	4.5	4.5
5280	182.17	100	6	3	1.5	4.5	4.5
5520	185.14	100	13.5	3	1.5	4.5	4.5
5720	200.14	99.6	12	3	1.5	4.5	4.5
5920	203.75	100	11.3	3	1.5	3.8	3.8
6160	206.86	100	10.5	2.3	1.5	3.8	3.8
6360	207.31	100	15.8	2.3	1.5	3.8	3.8
6480	211.44	100	13.5	2.3	0.8	3.8	3
6680	212.11	100	12	5.3	3.8	3	6
Code:
Saturday	4	August	2007	18:00:10
Group A:	'115			Group B:	'031
Engine Speed	Engine Load	Spec. Boost	Actual Boost	Lambda Factor	Lambda Factor
 /min	%	 mbar	 mbar
3000	102.3	1580	1430	0.938	0.938
3120	106	1650	1460	0.93	0.914
3280	112	2110	1550	0.899	0.891
3480	119.5	2190	1650	0.852	0.844
3680	129.3	2280	1790	0.828	0.821
3920	145.9	2400	1950	0.821	0.828
4120	158.6	2460	2130	0.805	0.813
4400	169.9	2440	2320	0.797	0.805
4640	182.7	2430	2360	0.789	0.805
4880	184.2	2410	2520	0.797	0.805
5120	188	2400	2450	0.805	0.805
5400	179.7	2410	2500	0.789	0.805
5600	177.4	2410	2410	0.789	0.805
5840	175.2	2400	2440	0.797	0.805
6040	177.4	2400	2440	0.774	0.805
6240	174.4	2410	2470	0.789	0.805
6440	164.7	2410	2470	0.797	0.805
6560	169.9	2400	2440	0.797	0.805
6680	165.4	2410	2440	0.797	0.805
6840	159.4	2390	2300	0.789	0.805
6960	156.4	1090	2440	0.782	0.805
Code:
Saturday	4	August	2007	18:02:57
Group A:	'118			Group B:	'032
Engine Speed	Air Temp In	Boost Dut Cyc	Actual Boost	Idle O2 Adapt	Run O2 Adapt
 /min	°C	%	 mbar	%	%
2920	31	100	1260	1.3	3.9
3040	31	100	1370	1.3	3.9
3200	31	100	1480	1.3	3.9
3360	30	100	1580	1.3	3.9
3520	30	100	1660	1.3	3.9
3680	30	100	1750	1.3	3.9
3880	31	100	1910	1.3	3.9
4120	31	92.5	2170	1.3	3.9
4360	32	96.5	2310	1.3	3.9
4640	33	74.1	2410	1.3	3.9
4880	33	68.6	2500	1.3	3.9
5120	35	60.4	2480	1.3	3.9
5360	36	54.5	2420	1.3	3.9
5560	37	51	2440	1.3	3.9
5800	39	53.7	2430	1.3	3.9
6000	39	52.9	2450	1.3	3.9
6160	40	67.5	2500	1.3	3.9
6360	42	58.8	2500	1.3	3.9
6520	43	57.6	2440	1.3	3.9
6640	45	60	2340	1.3	3.9
6800	45	63.9	2470	1.3	3.9
6680	46	0	2330	1.3	3.9
Cat Temp
Code:
Group A:	'043
Engine Speed	Cat Temp	PostC O2 V	PostC O2 Test
1800-2200 RPM	>=300 C	0.1-0.9V	B1-S1 OK
 /min	°C	 V
3360	655	0.835	B1-S2 OK
3040	655	0.86	B1-S2 OK
3120	655	0.825	B1-S2 OK
3160	660	0.795	B1-S2 OK
3240	660	0.8	B1-S2 OK
3320	660	0.805	B1-S2 OK
3400	665	0.81	B1-S2 OK
3440	665	0.82	B1-S2 OK
3560	665	0.83	B1-S2 OK
3600	670	0.825	B1-S2 OK
3720	670	0.83	B1-S2 OK
3840	675	0.83	B1-S2 OK
3920	680	0.835	B1-S2 OK
4040	680	0.83	B1-S2 OK
4120	685	0.84	B1-S2 OK
4320	685	0.835	B1-S2 OK
4400	690	0.84	B1-S2 OK
4520	695	0.835	B1-S2 OK
4680	700	0.835	B1-S2 OK
4760	705	0.835	B1-S2 OK
4920	710	0.84	B1-S2 OK
5040	715	0.84	B1-S2 OK
5160	720	0.835	B1-S2 OK
5240	725	0.835	B1-S2 OK
5400	730	0.835	B1-S2 OK
5480	735	0.84	B1-S2 OK
5560	740	0.835	B1-S2 OK
5680	745	0.84	B1-S2 OK
5800	750	0.84	B1-S2 OK
5880	755	0.845	B1-S2 OK
6000	760	0.845	B1-S2 OK
6120	765	0.84	B1-S2 OK
6200	770	0.84	B1-S2 OK
6280	775	0.84	B1-S2 OK
6360	780	0.85	B1-S2 OK
6440	785	0.84	B1-S2 OK
6480	790	0.835	B1-S2 OK
6560	795	0.845	B1-S2 OK
6640	800	0.84	B1-S2 OK
6720	805	0.84	B1-S2 OK
6760	805	0.84	B1-S2 OK
6760	810	0.85	B1-S2 OK
6120	815	0.69	B1-S2 OK
5400	815	0.07	B1-S2 OK
5320	810	0.015	B1-S2 OK
5200	810	0.005	B1-S2 OK
5040	810	0.005	B1-S2 OK
4920	805	0	B1-S2 OK
4800	805	0	B1-S2 OK
4680	805	0	B1-S2 OK
4560	800	0.005	B1-S2 OK
4400	800	0	B1-S2 OK
4320	800	0	B1-S2 OK
4200	795	0	B1-S2 OK
4160	795	0	B1-S2 OK
4120	790	0	B1-S2 OK
4040	790	0	B1-S2 OK
3920	790	0	B1-S2 OK
3840	785	0	B1-S2 OK
3720	785	0	B1-S2 OK
3640	780	0	B1-S2 OK
3520	780	0	B1-S2 OK
3440	780	0	B1-S2 OK
3320	775	0	B1-S2 OK
3240	775	0	B1-S2 OK
3120	775	0	B1-S2 OK
3080	775	0	B1-S2 OK
2960	770	0	B1-S2 OK
2840	770	0	B1-S2 OK
2760	770	0	B1-S2 OK
2680	765	0	B1-S2 OK
2600	765	0	B1-S2 OK
2480	765	0	B1-S2 OK
2400	765	0	B1-S2 OK
2280	760	0	B1-S2 OK
2160	760	0	B1-S2 OK
correction factor near 7.... bit high on the time id say!
cat temp over 800 sounds high to me also
im running 800C at start of DP
Looks good to me mate.
Fueling good, Air mass good, A CF approaching 7 is acceptable i wouldn't worry about it. Remember its still learning and adapting. Surprisingly high intake temps at high revs considering fmic. Duty cycle looks like its not even trying.
that power must be giving you a few white knuckle moments.;)
Don't forget a proportion of the intercooler is covered up at the moment. I need to do a bit of hacking!
The power is really fun as long as you remember there's sod all happening sub 4k, so you need to keep it on the boil. Wheelspin and torque steer are a bit of an issue in the lower gears. Overtake on full boost, and the car you've passed is suddenly a tiny dot in the rear view mirror. :happy:
Thanks for your input, Carl. :)
more hacking your car is now stage 3 weight reduction isnt it?? lol
There's a bit to go, last time I weighed it it was 1380kg with about 20 litres of fuel. :rolleyes:
Here's T6 HB 7 22.5 degrees
Code:
Saturday	4	August	2007	20:01:35
HB7 T6	22.5 degrees
2920	56.53	100	15.8	0	0	0	0
3080	64.44	100	22.5	0	0	0	3
3280	72.03	100	24.8	0	0	0	3
3440	81.81	100	23.3	0	0	0	3
3680	97.25	100	15	0	3	0	2.3
3880	116.28	100	13.5	0	3	0	2.3
4160	133.08	100	10.5	0	3	0	2.3
4400	147.72	100	10.5	0	3	0	2.3
4640	164.56	100	9	0	3	0	2.3
4920	176.5	100	6	0	3	0	1.5
5240	183.19	100	7.5	0	2.3	0	0.8
5440	184.22	100	9	0	0.8	3	0
5680	191.92	100	12	0	0.8	3	0
5880	199.53	100	9.8	0	0.8	3	0
6080	202.75	100	11.3	0	0.8	2.3	0
6280	207.03	100	14.3	0	0	2.3	0
6480	207.72	100	14.3	0	3	1.5	0
6680	206.06	100	14.3	0	3	1.5	0
T8 HB8 22 degrees
Code:
Saturday	4	August	2007	20:09:30
3000	61.03	100	21.8	0	0	0	3
3160	67.08	100	21	0	0	0	5.3
3440	79.83	100	24.8	0	3	3	5.3
3600	88.47	100	20.3	0	3	6	4.5
3800	107	100	14.3	3	3	6	4.5
4040	123.11	100	12.8	3	3	6	4.5
4280	137.61	100	10.5	3	2.3	5.3	3.8
4480	156.42	100	6.8	2.3	2.3	5.3	3.8
4720	167.19	100	5.3	2.3	2.3	5.3	3.8
4960	176.33	100	5.3	2.3	2.3	5.3	3.8
5200	181.22	100	6.8	2.3	2.3	4.5	3
5400	184.22	100	6.8	2.3	2.3	4.5	3
5560	186.47	100	10.5	2.3	2.3	4.5	3
5760	195.81	100	9	1.5	1.5	3.8	3
5920	197.31	100	10.5	1.5	1.5	3.8	2.3
6080	207.72	100	12.8	1.5	1.5	3	2.3
6240	204.39	100	12	1.5	1.5	3	2.3
6400	205.19	100	12	0.8	0.8	3	2.3
How about this for the boost on T6 HB8........:D
Code:
3120	94.7	2030	1290	0.899	0.953
3320	108.3	2100	1460	0.914	0.922
3480	120.3	2200	1570	0.875	0.86
3680	129.3	2300	1750	0.828	0.821
3880	148.1	2410	1890	0.828	0.821
4120	159.4	2460	2110	0.805	0.813
4400	171.4	2450	2280	0.805	0.805
4720	180.5	2420	2350	0.805	0.805
5000	188	2420	2470	0.805	0.805
5240	188	2420	2450	0.797	0.805
5480	182	2420	2460	0.789	0.805
5720	175.9	2410	2330	0.789	0.805
5960	174.4	2400	2480	0.789	0.805
6160	172.2	2390	2320	0.789	0.805
6360	170.7	2400	2510	0.789	0.805
6520	165.4	2400	2420	0.797	0.805
6680	163.2	2390	2460	0.797	0.805
6840	157.9	2390	2450	0.805	0.805
7000	157.9	2390	2390	0.797	0.805
HB9 T5/6 then :D Unless heat is an issue, highest MAF reading on HB7 T7 log
Certainly delivers boosts at the top end. Monster.
Not use to seeing more timing pull low down then less higher up...
Using your formula for scaling what BHP does that give (I can't remember LC MAF size)
I was hoping someone would come along and explain that.
I'll go and measure the ID of my old tube now. Do you know what the ID of an LCR MAF is?
:cheers:
Can't remember - I posted it some time ago, but can't find it now...
