good advise from m0rk re egt's if now looking at timing...
I cant remember if your running your water/meth on these logs or not.. for its contribution to afr or not.. ign timing, and or pull, will be balance of CF,EGT and lambda (but you know all that already)
some great prpogress Dave.
well done
Cheers Bill. Yes, I'm running 50% wmi, it just isn't showing on lamda, I assume because none is being burnt. I'll try increasing the timing now and see it that makes the lambda value drop....
Yeah, sounds like your getting there.
Personally i'd fit an egt into the manifold, as i wouldn't care what the temps are post turbo, its cylinder temps that i want to know.
Thanks Jon.
That's the big question, or rather dilemma for me.
I haven't a big
problem with taking the cast ATP manifold off and drilling/tapping for a sensor. However, I'm kind of nervous of undoing mani>turbo bolts. Last time (on my K03S) I went to undo them, the bolts had turned to case-hardened cheese and snapped off into the turbo. (I've got A4 stainless bolts in this time, but I'm still very apprehensive.)
My real feeling is that if I take that ATP mani off, I don't want to put it back on again - in which case I'd be moving from GTRS Eliminator to a proper Disco Potato.
.....Or I get a boss fitted to my DP. - but if that has to come off, would I be better ditching the K03 style fitting and moving to..........
.........or a strap-on boss with an external sensor - not hugely accurate, but better than nothing......
I fear for pre-turbine personally, although its the best place technically to install one... loose the thermocouple and its clips your turbine on the way out.
mines on turbine outlet 50mm from turbine itself.. worked well for me there.
Yes, in an ideal world......... I think if I invested more ££££ in turbo/engine, I'd become increasingly concerned about minimising the chance of the setup lunching itself.
At the moment, I think I'll be happy to try and prove it is possible to get good reliable bhp from the eliminator. After that, it's another ball game as we all know. Bottom end, head ............
This has been frustrating, but a load of fun in learning.
deffo the bumper..
Trouble is Pat, the bumper went to the local tip late last year. The brain isn't exactly the latest model either..........
