my max onset of boost is 28psi which is where I have set the Snow to deliver its max.. onset starts at 14psi. I cant remember my jet size off hand.
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
my max onset of boost is 28psi which is where I have set the Snow to deliver its max.. onset starts at 14psi. I cant remember my jet size off hand.![]()
a b c d e f g h i j
4680 15.98 145.39 16.84 198.73 1.37 0.92 17.76 209.57 1.44
5080 15.64 168.53 17.89 211.13 1.25 0.92 18.81 221.96 1.32
5480 16.32 182.47 20.14 237.65 1.30 0.92 21.06 248.49 1.36
5840 16.66 200.81 21.91 258.54 1.29 0.92 22.83 269.38 1.34
6240 15.98 208.39 22.46 264.97 1.27 0.92 23.37 275.81 1.32
6600 15.64 215.78 23.25 274.30 1.27 0.92 24.16 285.13 1.32
6920 14.96 216.22 23.31 275.09 1.27 0.92 24.23 285.93 1.32
7240 14.28 217.50 23.28 274.73 1.26 0.92 24.20 285.57 1.31
7480 13.94 219.69 23.48 277.08 1.26 0.92 24.40 287.92 1.31
I love maths![]()
Column g is methanol input as if it was petrol at 6:1 afr based on 300cc inj at 50:50 w:m and 0.9 density
I've worked out that 6:1 is close to stoich for methanol at 6.4, but I can't quite work out how you get 0.92 g/s of methanol. (I think I've misunderstood you, I take it as 300cc w:m injected per min = 5cc/sec = 2.5cc of methanol = 1.98g/s )
One thing I've noticed dave is that you're running more airflow than me as your boost overshoots. Now I'm running 24-26psi at that point, so you have a fairly hefty uncontrolled overshoot of boost to about 30psi. Probably not the best idea
Dave
I did my numbers after 3 pints and a long day, but I'll try again 300cc at 0.9 density (meth=0.8 water=1) is 270g. 1/2 is methanol, so 135g, so 2.25g/s
This requires 13.5g of air at stoich for meth which is enough to burn 0.93g of petrol at stoich.
0.92 or 0.93, I'm not saying it's 100% accurate, but near enough.
My boost is 24-26psi controlled on n75, but my n75 duty cycles are in the controllable range, so 60-80%. At boost onset, my n75 is only having to dial back from 100% to say 60% which will give a lot less overshoot than 100% back to 10%.
Your mbc is just a bleed valve, and should limit maximum boost, so remove the spike (to an extent), and should help you hold boost at the top end. You could just put a weaker spring in your actuator, or get an adjustable one.
Interesting, Bill - I can't set mine to start higher than 8psi. (that's max on the controller)![]()
mines their "race" stuff.. if thats relevant.
..............In other words VE was dropping as fast as revs were rising, cancelling any extra airflow that the engine should be consuming as revs rise out...........
I've managed to set it so that (on the gauge) it reliably and repeatably pulls to 23psi before settling back to 22psi. It might be in my mind, but it does feel smoother now.How does that feel dave, and when do you get full spool by now? Quicker with the mbc?
Saturday 12 January 2008
06A 906 032 HN 1.8L R4/5VT 0002
Group A: '002 Group B: '020
Idle speed Engine load Inj. period Air mass in Idle Stabilization Idle Stabilization Idle Stabilization Idle Stabilization
700-820 rpm 15-25% 2.0 - 4.0 ms 2.0-4.5 g/s
/min % ms g/s CF CF CF CF
3520 135.3 10.54 96.47 0 0 0 0
3760 161.7 12.92 120.28 0 0 0 0
4040 188 14.96 149.67 0 0 0 0
4280 191.7 15.98 173.67 0 0 0 0
4560 191.7 16.32 186.81 0 0 0 0
4800 191.7 16.66 194.58 0 0 0 0
5040 191.7 16.32 198.81 0 0 0 0
5320 191.7 15.98 205.25 0 0 0 0
5560 191.7 15.3 205.69 0 0 0 0
5720 189.5 14.96 203.78 0 0 0 0
5920 188 14.96 208.42 0 0 0 0
6120 189.5 14.96 223.58 0 0 0 0
6280 182 14.28 216.56 0 0 0 0
6440 178.9 13.94 223.67 0 0 0 0
6640 173.7 13.6 219.69 0 0 0 0
6800 168.4 13.26 219.69 0 0 0 0
6920 163.2 12.58 221.44 0 0 0 0
7000 162.4 12.92 218.83 0 0 0 0
7160 158.6 12.92 215.53 0 0 0 0
7200 157.1 12.92 224.11 0 0 0 0
Group A: '002 '031
rpm Inj. Air Lambda Lambda Fuel Fuel A/F Air Scaling
/min ms g/s Actual Target litres Weight Actual
g/s g/s
3600 10.2 72.06 0.844 0.649 0.0112 8.27 12.41 102.59 1.42
3720 12.58 108.14 0.75 0.735 0.0143 10.54 11.03 116.19 1.07
3880 14.28 128.14 0.75 0.782 0.0169 12.48 11.03 137.56 1.07
4120 15.64 156.22 0.75 0.797 0.0197 14.51 11.03 159.98 1.02
4400 16.32 180.92 0.789 0.797 0.0219 16.17 11.60 187.55 1.04
4640 16.66 188.42 0.797 0.797 0.0236 17.41 11.72 203.95 1.08
4880 16.32 201.44 0.805 0.805 0.0243 17.93 11.83 212.23 1.05
5120 15.98 198.44 0.805 0.805 0.0250 18.42 11.83 218.03 1.10
5360 15.64 204.39 0.774 0.805 0.0256 18.88 11.38 214.79 1.05
5600 15.3 205.08 0.805 0.805 0.0262 19.29 11.83 228.32 1.11
5800 14.62 205.39 0.797 0.805 0.0259 19.10 11.72 223.72 1.09
6040 14.28 219.03 0.797 0.805 0.0264 19.42 11.72 227.56 1.04
6240 14.28 219.36 0.782 0.805 0.0272 20.07 11.50 230.67 1.05
6440 13.94 220.78 0.782 0.805 0.0274 20.22 11.50 232.40 1.05
6560 13.94 223.22 0.789 0.805 0.0279 20.59 11.60 238.85 1.07
6720 13.6 222.53 0.797 0.805 0.0279 20.58 11.72 241.12 1.08
6880 12.92 217.53 0.789 0.805 0.0272 20.02 11.60 232.17 1.07
7000 12.58 212.78 0.782 0.805 0.0269 19.83 11.50 227.96 1.07
7120 14.28 220.11 0.797 0.805 0.0311 22.90 11.72 268.25 1.22
7200 13.26 217.53 0.75 0.805 0.0292 21.50 11.03 237.03 1.09
7200 13.94 222.36 0.75 0.805 0.0307 22.60 11.03 249.19 1.12
