DPJ's GTRS Eliminator Install and Development
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
my max onset of boost is 28psi which is where I have set the Snow to deliver its max.. onset starts at 14psi. I cant remember my jet size off hand. :think:
Wilko
Badge snob
Code:
a	b	c	d	e	f	g	h	i	j
4680	15.98	145.39	16.84	198.73	1.37	0.92	17.76	209.57	1.44
5080	15.64	168.53	17.89	211.13	1.25	0.92	18.81	221.96	1.32
5480	16.32	182.47	20.14	237.65	1.30	0.92	21.06	248.49	1.36
5840	16.66	200.81	21.91	258.54	1.29	0.92	22.83	269.38	1.34
6240	15.98	208.39	22.46	264.97	1.27	0.92	23.37	275.81	1.32
6600	15.64	215.78	23.25	274.30	1.27	0.92	24.16	285.13	1.32
6920	14.96	216.22	23.31	275.09	1.27	0.92	24.23	285.93	1.32
7240	14.28	217.50	23.28	274.73	1.26	0.92	24.20	285.57	1.31
7480	13.94	219.69	23.48	277.08	1.26	0.92	24.40	287.92	1.31
Column a is rpm
Column b is injector on time for 550cc inj
Column c is maf reading (maf is 1.32 times the area the ecu thinks it is)
Column d is fuel flow in g/s (see dpj's calc)
Column e is calculated airflow at 11.8:1 afr which is what it runs
Column f is e/c
Column g is methanol input as if it was petrol at 6:1 afr based on 300cc inj at 50:50 w:m and 0.9 density
Column h is petrol+meth (back calculated as if it was all petrol)
Column i is calculated airflow based on petrol and meth input
Column j is i over c
odd that its i/c is almost exactly 1.32 which is the same as the calculated maf scaling based on area of the maf i'm using over a cupra r maf which the modified stage 3 code thinks I'm running.
I love maths:p
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I'll give up puzzling over this for now :hide: I've worked out that 6:1 is close to stoich for methanol at 6.4, but I can't quite work out how you get 0.92 g/s of methanol. (I think I've misunderstood you, I take it as 300cc w:m injected per min = 5cc/sec = 2.5cc of methanol = 1.98g/s )
Apart from that, your figures make an impressively tight case. :yes:
It makes me more confused about what my methanol is doing - it's becoming more and more apparent that very little of it is being burned. :confused:
One thing I've noticed dave is that you're running more airflow than me as your boost overshoots. Now I'm running 24-26psi at that point, so you have a fairly hefty uncontrolled overshoot of boost to about 30psi. Probably not the best idea
You mean around 4-5k rpm? My boost gauge seems reasonable accurate and it's showing about 28psi before it falls. What can I do to control it - should I be dropping the boost on my SPS3? If that's the case, should I dispense with experiments with the mbc and attempts to pull 2.5 mbar across the range? Are you running a boost controller, John?
Thanks for your interest. :worship:
Wilko
Badge snob
Dave
I did my numbers after 3 pints and a long day, but I'll try again 300cc at 0.9 density (meth=0.8 water=1) is 270g. 1/2 is methanol, so 135g, so 2.25g/s. Your 120g/min is actually the right way to calculate it, but hell I was drunk.
This requires 13.5g of air at stoich for meth which is enough to burn 0.93g of petrol at stoich.
0.92 or 0.93, I'm not saying it's 100% accurate, but near enough.
Your calc would give 0.88.
My boost is 24-26psi controlled on n75, but my n75 duty cycles are in the controllable range, so 60-80%. At boost onset, my n75 is only having to dial back from 100% to say 60% which will give a lot less overshoot than 100% back to 10%.
Your mbc is just a bleed valve, and should limit maximum boost, so remove the spike (to an extent), and should help you hold boost at the top end. You could just put a weaker spring in your actuator, or get an adjustable one.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Dave
Ahhhh - I see now! I hadn't thought about the last stage calculating petrol equivalent. :redface:
Cheers. :)
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
mines their "race" stuff.. if thats relevant.
ahhh, I see. :)
Wilko's made an interesting point (probably obvious to you John, but it's only just dawned on me.........) Once you've calculated the 'actual' flow of your maf, you can use the figure at each rpm reading to calculate boost. (by proportioning that figure to the weight of air that would flow through the engine at that rpm reading at standard atmospheric pressure.) Am I correct in saying you should then adjust the result by volumetric efficiency?
Wilko
Badge snob
Dave
You have to guess a bit at volumetric efficiency, but high 90's% in the mid range, where the cams are efficient, to low 80's at the top end where the head/cams aren't are not out of the ordinary.
I found the small port with standard cams had fixed airflow over 6200rpm for constant boost. In other words VE was dropping as fast as revs were rising, cancelling any extra airflow that the engine should be consuming as revs rise out.
VE will also drop as boost rises, as you're measuring pressure just before the inlet manifold. The pressure drop across the manifold and valve train will increase as flow(boost) increases.
In other words, VE will be better at 1 bar than at 1.5bar of boost.
250g/s seems to be about the max flow for the small port at 1.5bar boost. On my large port with cams, and inlet manifold, it is nearer to 300g/s at 1.5bar with a 7500rpm limit. This appears to continue to rise linearly, so more revs (and a larger turbo) would allow for more flow.
I think if you're going for a bigger turbo (>350hp) then a big port and cams will give efficiency (and longevity/safety gains), as will reducing pressure drop across the whole intake system.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
As I had the car with me today, I had a stop-start journey home while I kept adjusting the mbc.
:cartman: I've managed to set it so that (on the gauge) it reliably and repeatably pulls to 23psi before settling back to 22psi. It might be in my mind, but it does feel smoother now.
I'll try and log it later, then I can fine tune the mbc.
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
How does that feel dave, and when do you get full spool by now? Quicker with the mbc?
It does feel fine, Phil. I'm embarrassed to say I'm not sure if the spool has changed - I'll have to check. I'm really pleased John pointed out the overboost, it does answer why the N75 was struggling to cope. I'm wondering now if it was responsible for some of the CFs, and if I now might be able to go back and advance the timing.......
I really feel I've made a step forward today. :)
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
more revs more power so long as your total system can flow it.. (inlet and exhaust)
had a good chat with CNC heads at autosports show with respect to big port head... shared some info with them, so they may relook at what possible from smallport on next setup, as largeport heads are not as readily available as smallports.. but the market for those who need heads which can flow that high is going to be very small here in the uk i think
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
Wooo Hoooo! :D
Tweaking out the overboost has virtually removed the dip in my airflow. I've now done runs at T9 HB9 with no correction factors. It looks like I can now dial in some timing. :D
Code:
Saturday	12	January	2008
06A 906 032 HN		1.8L R4/5VT         0002
Group A:	'002			Group B:	'020
Idle speed	Engine load	Inj. period	Air mass in	Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
700-820 rpm	15-25%	2.0 - 4.0 ms	2.0-4.5 g/s
 /min	%	 ms	 g/s	 CF	 CF	 CF	 CF
3520	135.3	10.54	96.47	0	0	0	0
3760	161.7	12.92	120.28	0	0	0	0
4040	188	14.96	149.67	0	0	0	0
4280	191.7	15.98	173.67	0	0	0	0
4560	191.7	16.32	186.81	0	0	0	0
4800	191.7	16.66	194.58	0	0	0	0
5040	191.7	16.32	198.81	0	0	0	0
5320	191.7	15.98	205.25	0	0	0	0
5560	191.7	15.3	205.69	0	0	0	0
5720	189.5	14.96	203.78	0	0	0	0
5920	188	14.96	208.42	0	0	0	0
6120	189.5	14.96	223.58	0	0	0	0
6280	182	14.28	216.56	0	0	0	0
6440	178.9	13.94	223.67	0	0	0	0
6640	173.7	13.6	219.69	0	0	0	0
6800	168.4	13.26	219.69	0	0	0	0
6920	163.2	12.58	221.44	0	0	0	0
7000	162.4	12.92	218.83	0	0	0	0
7160	158.6	12.92	215.53	0	0	0	0
7200	157.1	12.92	224.11	0	0	0	0
Do I pull boost down a fraction and chase timing now?
Code:
Group A:	'002		'031
rpm	Inj. 	Air 	Lambda Lambda Fuel  Fuel    A/F	 Air	 Scaling
 /min	 ms	 g/s	Actual	Target	litres	Weight		Actual
						g/s		g/s
3600	10.2	72.06	0.844	0.649	0.0112	8.27	12.41	102.59	1.42
3720	12.58	108.14	0.75	0.735	0.0143	10.54	11.03	116.19	1.07
3880	14.28	128.14	0.75	0.782	0.0169	12.48	11.03	137.56	1.07
4120	15.64	156.22	0.75	0.797	0.0197	14.51	11.03	159.98	1.02
4400	16.32	180.92	0.789	0.797	0.0219	16.17	11.60	187.55	1.04
4640	16.66	188.42	0.797	0.797	0.0236	17.41	11.72	203.95	1.08
4880	16.32	201.44	0.805	0.805	0.0243	17.93	11.83	212.23	1.05
5120	15.98	198.44	0.805	0.805	0.0250	18.42	11.83	218.03	1.10
5360	15.64	204.39	0.774	0.805	0.0256	18.88	11.38	214.79	1.05
5600	15.3	205.08	0.805	0.805	0.0262	19.29	11.83	228.32	1.11
5800	14.62	205.39	0.797	0.805	0.0259	19.10	11.72	223.72	1.09
6040	14.28	219.03	0.797	0.805	0.0264	19.42	11.72	227.56	1.04
6240	14.28	219.36	0.782	0.805	0.0272	20.07	11.50	230.67	1.05
6440	13.94	220.78	0.782	0.805	0.0274	20.22	11.50	232.40	1.05
6560	13.94	223.22	0.789	0.805	0.0279	20.59	11.60	238.85	1.07
6720	13.6	222.53	0.797	0.805	0.0279	20.58	11.72	241.12	1.08
6880	12.92	217.53	0.789	0.805	0.0272	20.02	11.60	232.17	1.07
7000	12.58	212.78	0.782	0.805	0.0269	19.83	11.50	227.96	1.07
7120	14.28	220.11	0.797	0.805	0.0311	22.90	11.72	268.25	1.22
7200	13.26	217.53	0.75	0.805	0.0292	21.50	11.03	237.03	1.09
7200	13.94	222.36	0.75	0.805	0.0307	22.60	11.03	249.19	1.12
