And it made 330ish with 250g/s?
Im not fussed about the cost as i knew that when i started...
Seems wilko on his ihi made 343g/s with revo stage 3....So it does produce the power.
there is no stage 3 listed for ibiza ecu's on revo's software list
confirm this with them first before making up your mind fella
Are you defo sure Bill as im sure someone called '' Custard Cupra'' Was using Stage 3 but iil ask kev see what he says...
As parts start arriving Il post up piccys..
1x ECS Magnetic Sump Plug
1x ECS Low Running Thermostate 180Degrees
i may be wrong here but thinking back when custard cupra had his.... im pretty sure it was jabba mapped on ihi.
I was'nt sure he is actually on DTA now.. if memory serves. been a while since we spoke
Just for you Jamie ;D
What size nuts are on the Head to manifold is it m8?
Looks just like my manifold. Only difference is I have relief cuts between the runners. If the mating surface has been milled flat then you shouldn't need a gasket. I have a gasket on mine but that's because I didn't know any better at the time and it's been fine.
You could talk to Bill about sleeving the manifold and turbine inlet, which would definately seal it if your worried but at extra cost.
The spanner size for the nuts is 12mm, but I don't know the thread size off the top of my head.
