Alright for some, the engine wasnt convincing me anyway, its actually made me look forawrd to doing it now, 1400 is what its gona cost :O, suppose it aint bad as a bam engine 2nd hand is about 1500, then a clutch ontop of that, AUQ engine, bam piston and rods, new big end bearings, hone cylinders, new rings, head gasket & bolts, exhaust gaskets, inlet gaskets, injector seals, timing belt kit & wp, rocker gasket, plugs, oil & filter, coolant, then theres the other bits like a coolant bottle some hoses, oil cooler, dipstick tube, rad mounts, air con gassing, i will have missd some bits off but you get the picture, oh and an ECS magnetic drain plug, dogbone mounts, and rack mount bush
power steering fluid, hose clips, turbo mounting bolts, make a new turbo support bracket, secondary water pump, cam postion sensor crank sensor. Thats about it matey
should be a solid motor then.
After that comes an I/C and mapping... wooo
