Yep, a Forge TIP is a must too.
So the list stands at:
Remap
Rear ARB
Forge TIP
Rear spacers
Anything else?
Before the re-map...replace the powerflow with a turbo back system of some sort!.....and you know what?? i might be done ha ha
Remap
Rear ARB
Forge TIP
Rear spacers
Anything else?
Yea, I need a turbo back exhaust then thats prob me done
What exhaust you got at the mo? standard?
Looks good mate! Ride hiehgt is spot on!! *thumbs up*
Id def recommend a Whiteline rear ARB mate, has def improved the handling of my Cupra!! Back end feels a lot more stable under heavy cornering!!
Got a cat-back powerflow with a 6x4 oval tip! does the job for now! might just find a sport cat and downpipe to fit that system!
Well if you do change it I might have it off you mate![]()
Nice pics and very nice car!![]()
right-o.......i think its time for bumblebee to get a re-map, Been speaking to the garage that are going to be doing the re-map, and i have chosen a custom Rolling road map just so i can get the most out of it.
I am getting my downpipe and sports cat fitted next week, but should there be anything else that i should be looking to replace or upgrade before going down the re-map route.....i.e 4 bar fuel regulator??
Any help would be good....list of mods is in my signiture....thanks![]()
Its upto the mapper if you need a 4bar fpr mate.
Only other things I would say are a forge TIP and DV pluss a high flow air filter.
i really like your car ive not seen a yellow mk4 cupra in the metal before.
I did ask the qeustion to the mapper and his response was....."you can put one in...i might or might not make a difference" so was just looking for some advice on here, i already have the 007p and a jetex cone filter, looks like i mihg thave to do some shopping on Forge then eh?!
There would be no harm in using one... As long as it is mapped to use it. Not expensive. £15 on E38
Revo say to use them for stage 2, not sure what others do. Are you still going to Star?
