Understood, will remove it and break the hard line as I won't be selling that anyway.Sounds promising but would have thought that you'd have disconnected the AC line already seeing as the slam panel was previously removed.
Yeah the main AC line to the compressor needs to be undone.
I usually break the hardline off as well to allow more room when taking the engine out if I know its not needed.
Sent from my SM-G986B using Tapatalk
I'm pretty sure everything is disconnected, the ground cable aswell. So now just lower the car onto a pallet and undo the two bolts on each engine mount, raise the car and secure the engine onto the pallet, right?
Just wondering, only tyre I have is a 225 wide so it'll add a lot of height to the pallet and would most likely increase the price too, is there something else I can put between the sump and the pallet to make sure the sump doesn't get messed up? Cheers
