I usually reset with Vagcom, if you use the battery disconect route you will have to reset the clock and code the radio.
oh no! Such hardship!
Did you do this on Ben's car then?
I'll give Revo a ring in the morning to find out about this update. I'm fairly sure Kev said it wasn't an update as such, just something they did to try and help Ben out.
i knew i had the same code as everyone else just didnt know if i had the earlier version or the the later one
Our Revo dealer Mega 4 said there was an updated less aggresive code.
how do you reset the ECU with vag com?!
would save me a lot of hassel me thinks!![]()
Hi mate, go into Vagcom, then Engine, Basic settings, type in 060 then hit go, wait for the counter to go to 8 then the reset is done. What sort of power does your CR run?
WOW and cheers!!!
lol @ the amount of times i have disconnected my battery when i have had vag com all this time!
my power... well not too sure, got 270bhp and 352lbs at jabba (yes LBS!) but my car is a little bit quicker since back in feb, now holds boost better and runs a couple more psi (i had a split F pipe!)
but you know wat dynos are like...
but i did get 13.8 @ pod against a stupidly strong head wind!![]()
Same sort of power as our Leon then, would be good to see if my Quaife diff gives me any better times down the 1/4.
Ben that 8 may be just a glitch, you know when you've got serious timing pull when all cylinders start showing figs of 5 and above (if its fueling related the same mix will be seen by all cylinders). Some cylinders are worse than others. One off figures wouldn't really worry me.Ok did a big log today (not that sort of log) anyway my highest g/s was the following
4560 rpm - 141.25g/s
5560 rpm - 185.44g/s
6560rpm - 116.58gs
4880rpm - 175.17g/s
5400rpm - 180.03g/s
5920rpm - 189.08g/s
6360rpm - 181.56g/s
6280rpm - 0g/s
That was a 2nd and 3rd gear run, i had no timing pull back what so ever, my car was requesting 1.1bar of boost and got 1.1 bar of boost it peaked at 1.4bar.
I tried a 4th gear run but didnt get to redline, however i got to 5520rpm where i saw 179.19g/s but at the following rpm i had this timing pull back, all on boost 6 timing 6 and using v-power.
1560rpm - 0,0,0,6
1720rpm - 0,0,0,6
1960rpm - 0,0,0,5.3
2240rpm - 0,0,0,5.3
2560rpm - 0,0,0,4.5
2920rpm - 0,0,0,3.8
3280rpm - 0,0,0,3.8
3640rpm - 0,0,0,3
4040rpm - 0,0,0,3
4400rpm - 0,0,0,2.3
and then fallng untill i reached 5520rpm where i had 0,0,0,0.8
in 4th it was requesting 1.3bar and getting 1.3bar it peaked at 1.45bar, so that to me means my car is still running lean to produce timing pull back like that on t6 and v-power
352lbs of torque on the standard turbo
6560rpm - 116.58gs
4880rpm - 175.17g/s
5400rpm - 180.03g/s
5920rpm - 189.08g/s
6360rpm - 181.56g/s
6280rpm - 0g/s
1560rpm - 0,0,0,6
1720rpm - 0,0,0,6
1960rpm - 0,0,0,5.3
2240rpm - 0,0,0,5.3
2560rpm - 0,0,0,4.5
2920rpm - 0,0,0,3.8
3280rpm - 0,0,0,3.8
3640rpm - 0,0,0,3
4040rpm - 0,0,0,3
4400rpm - 0,0,0,2.3
