Phil, DPJ
Your engines are 4 stroke, so each piston only sucks in air each consecutive rev.
You need to divide your cc by 2, times by revs per sec, and then times by 1.15/1000 (realistic density of air at the temps we're talking.
so 1781/2 x 6320/60 x 1.15/1000 = 107.9g/sec at 100% VE and atmospheric pressure at the intake manifold.
So yours is 2.1 times this as you're running 1.1 bar ish at that point, so would be 226 at 100% VE so if you're at 200ish, you're at 88% VE.
At those sorts of revs, and 1.4 bar of boost, I'm seeing 245g/s with IHI, 258g/s being 100%VE, so I'm at 95%VE, but have Ported big port head, cams etc.
VE is simply can you get the full volume of the cylinders filled with air at the correct density.
Here's a great calculator to play with. Helps to sus out some of the bull power claims at peoples suposed boost levels.
http://not2fast.wryday.com/turbo/glossary/turbo_calc.shtml
Compression ratio effects cylinder pressures and burn rate, and higher compression makes more power, as long as you're within the knock limits of the fuel that you're using.
