Cheap HID's
RobM
Back from the dead...
Sep 27, 2006
4,982
Southampton
There is a complete shield under the entire engine, so without getting the car up on ramps and removing that, it's not easy to get access from underneath. Plus there are the twin intercoolers on each side.
RobM
Sep 27, 2006
4,982
Southampton
That might explain it then. Still, quite happy where the drivers side is and the passenger side is better, so all in all I'm quite content :)
kez
Jan 29, 2007
1,014
Dewsbury, West Yorkshire
anyone tried the slim version they do?
i'm tempted to buy two slim versions for my LCR - H7 and H1 and cram them into the same space as one 'normal' kit
it's an extra $80, though.
failing that, is there room to mount 4 'normal' ballast kits in the leon?
Arnolfini
Muppet
Nov 23, 2006
179
The Gates of Hell (Croydon)
I can't see you having too much of a problem mounting 4 ballasts... it's what I'm planning on doing!
That said , it might be a little more tricky if you're planning on keeping it all looking OEM.
I've currently got one ballast stuck to the washer bottle, and the other stuck to the body panel right next to the airbox (both using that 3M Dual Lock heavy duty velcro stuff).
Planning on sticking the second drivers side ballast to the other side of the washer bottle, and the second passenger side one underneath the slam panel for the headlight (like UncleFester). It might not look brilliant, but it should do the job just fine. Besides which, they're easy enough to remove and relocate if I decide I want to start entering shows!
Just pop your bonnet and have a look round the engine bay - you're sure to find plenty of locations.
kez
Jan 29, 2007
1,014
heh. i may just stick them all to the underside of the bonnet, and never open it :rolleyes: :D
i got a reply from mydepots who say that the slim ones aren't that much slimmer, and you can't mount them on top of each other, so there goes that idea
think i'll just go for two md01 kits.
RobM
Sep 27, 2006
4,982
Southampton
The ballasts need a bit of space around them, especially the top part of them, so they don't overheat. So stacking them would cause problems in the long term.
Czechboy
Tarmac terrorist
Apr 14, 2005
1,607
Hampshire
Was also thinking of getting a second set for the high beams but in the end decided against it because:
a) everytime you just want to flash someone it will need the high voltage kickstart (not sure if it will even just flash)
b) havent had to use high beams since I've installed the HID :D
Mig
RobM
Sep 27, 2006
4,982
Southampton
It will definitely flash, and it will be full brightness too because of the instant voltage spike when they are first turned on.
But I agree about your second point, I've not needed them much since I installed my HID's :D
Arnolfini
Muppet
Nov 23, 2006
179
I need my full beams every day, thanks to the little winding unlit roads that I drive down to get to and from work.
Whilst the HIDs are fantastic, and thousand times better than the halogens, I'm still using the full beams a lot, and the comparison with the HIDs makes the halogens seem even crappier than they did before. As such I reckon HID full beams are the way forward - and you can't go wrong at the price MyDepots are charging!
Really looking forward to getting the H1s installed... not only will the colour of the dipped and main beams match, but I reckon they'll be bright enough to see through stuff!
MMCrewcupra
94
so how much are you looking for a set of the hid kit for the full beam, the dipped ones iv just brought the super bright led ones recommended off here for about 16 quid i think, so its just the main beam i need isnt it,
Nathanio
1,226
West Sussex
www.w1pcs.co.uk
You have Sidelights (W5W), dipped (H7) and main (H1). Generally its not recommended to have HIDs for main beam due to the power at time.
If you have a read throught the sticky and this thread all will become clear
RobM
Sep 27, 2006
4,982
Southampton
There is no point in just upgrading the full beams, as you don't use them as often as your dipped (main) beams and your full beams will make your current main bulbs look like a candle in comparison!
Upgrade the main beams (You'll need a H7 kit) and you'll see what I mean. However impressed you are with your current bulbs... double it and add some more! ;)
