Carista app - Android
sharefe
21
West London
With my android note 3 and my cheap £5 Bluetooth ELM 327 odb2 an Altea 1.6 Diesel DSG I got the Carista pro and was playing with the settings managed to activate the following:
Allow configuring beep when locking/unlocking
*YES*
Beep when locking with remote
*YES*
Beep when unlocking with remote
*YES*
Gauge needle sweep at startup
*YES*
Lane-change turn signal auto-flasher count
*5 FLASHES*
Use low beams as daytime running lights
YES
Use fog lights as daytime running lights
YES
Coming-home lights
*ENABLED*
Coming-home lights mode
*MANUAL: FLASH HIGH BEAMS TO ACTIVATE*
Coming/leaving-home lights use…
*LOW BEAMS*
Coming-home lights duration
*10 SECONDS*
Turn off all lights when headlights are left on and ignition is switched off
*YES*
Flash brake lights in emergency stopping
*YES*
Brake lights work even when ignition is off
*NO*
Not working on my car that I can see:
Flash hazard lights in emergency stopping
Lower passenger-side mirror when in reverse gear (may need memory seats)
I am going to send a list to the developer to see if other settings can be activated please let me know if you have any ideas to add to this app.
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote:
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Unlock trunk when doors are unlocked
*YES* / NO
Blink turn signals when locking/unlocking with remote
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
*YES* / NO
Open/close windows and sunroof via long-press on remote
*YES* / NO
Open only driver's window via long-press on remote
YES / *NO*
Open sunroof via long-press on remote
YES / *NO*
Close sunroof via long-press on remote
YES / *NO*
Sunroof action when opening via remote
SLIDE / *TILT*
Open/close windows and sunroof by holding key in door lock
*YES* / NO
Blink turn signals when done closing windows via remote
*YES* / NO
Enable remote control buttons when ignition is on
YES / *NO*
Instruments / Display / Dings:
Instrument cluster region (affects ext. lights too)
GERMANY / EUROPE/OTHER / USA / CANADA / *GREAT BRITAIN* / JAPAN / SAUDI ARABIA / AUSTRALIA
Gauge needle sweep at startup (req. instrument cluster support)
*YES* / NO / NOT AVAILABLE
Seat belt warning
*ENABLED* / DISABLED
ENABLED / *DISABLED*
1 FLASH / 2 FLASHES / 3 FLASHES / 4 FLASHES / *5 FLASHES*
Push-to-talk (PTT) button function
PUSH-TO-TALK / *MUTE*
Lights:
Allow configuring daytime running lights via dash display
YES / *NO*
Use designated DRL bulbs as daytime running lights
YES / *NO*
YES / *NO*
YES / *NO*
Turn off daytime running lights ("wink") when turn signal is on
YES / *NO*
Turn off daytime running lights when parking brake is on
YES / *NO*
Coming-home lights
Leaving-home lights (req. auto headlights)
*MANUAL: FLASH HIGH BEAMS TO ACTIVATE* / AUTOMATIC: WHEN IT'S DARK (REQ. AUTO HEADLIGHTS)
*LOW BEAMS* / FOG LIGHTS
5 SECONDS / *10 SECONDS* / 15 SECONDS / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
*YES* / NO
Turn off front fog lights when high beams are on
YES / *NO*
Turn off rear fog lights when high beams are on
YES / *NO*
Cornering lights (using fog lights)
*YES* / NO
*YES* / NO
YES / *NO*
Other:
*YES* / NO
Auto-enable rear wiper when front wipers on and reverse gear engaged
*YES* / NO
Auto-enable rear wiper when front wipers on (interval) and reverse gear engaged
*YES* / NO
Auto-enable rear wiper when front wipers on (continuous) and reverse gear engaged
*YES* / NO
Additional 'tear' wipe after rear window washer use
*YES* / NO
Obtained with Carista 2.3 beta-3 for Android.
jimbo1876
43
I purchased the pro version of the app (£14.99) for iOS 8 which works via wi-fi ELM adapter. I am using this one http://www.amazon.co.uk/gp/product/B00DYOVXZ0?psc=1&redirect=true&ref_=oh_aui_detailpage_o03_s00 which initially I thought was faulty as it was working intermittently but I now realise that my bluetooth handsfree kit was interfering with the wi-fi signal from the dongle. I solved that issue by using an extension cable http://www.amazon.co.uk/gp/product/B00J2N0VG4?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 and my iPad and iPhone connect to the dongle first time every time and is producing reliable data now. Initially I was getting error codes for 3 out of 4 door locking mechanisms and my alarm ultrasound sensor not working. I haven't got issues with any of them but once I purchased the extension cable allowing the dongle to be much further away from the handsfree transmitter those errors no longer come up leaving only one genuine error which is the passenger side heated mirror element faulty. This is the only OBD2 app that detected this fault.
Of the customisations on offer for my 2007 FR 170 TDI I tried switching on the alarm beep but found it annoying but disabled the one button key press for lowering all windows as I have been caught out with that one before.
All in all for the outlay I think it is a fantastic app and combine it with something like Dash Commander and your phone/tablet becomes a fairly decent diagnostic tool.
These were the customisations available for my car
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Blink turn signals when locking with remote
*YES* / NO
Blink turn signals when unlocking with remote
*YES* / NO
Beep when locking with key
YES / *NO*
Beep when unlocking with key
YES / *NO*
Blink turn signals when locking with key
*YES* / NO
Blink turn signals when unlocking with key
*YES* / NO
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
*YES* / NO
*YES* / NO
Open windows via long-press on remote
YES / *NO*
Close windows via long-press on remote
*YES* / NO
YES / *NO*
YES / *NO*
*SLIDE* / TILT
Open/close windows and sunroof by holding key in driver-side door lock
*YES* / NO
Open/close windows and sunroof by holding key in passenger-side door lock
YES / *NO*
Open/close windows and sunroof by holding key in trunk lock
YES / *NO*
Open windows by holding key in door lock
*YES* / NO
Close windows by holding key in door lock
*YES* / NO
Open sunroof by holding key in door lock
YES / *NO*
Close sunroof by holding key in door lock
YES / *NO*
Alarm system
Alarm system disarming
VIA REMOTE OR KEY / *VIA REMOTE ONLY*
Re-lock doors automatically if you unlock, but don't open a door
YES / *NO*
*YES* / NO
Delay alarm activation
*YES* / NO
GERMANY / EUROPE / USA / CANADA / *GREAT BRITAIN* / JAPAN / SAUDI ARABIA / AUSTRALIA
Seat belt warning
Lights
Daytime running lights
*OFF* / ALL LIGHTS / HEADLIGHTS ONLY
YES / *NO*
Coming-home lights
Leaving-home lights
*BASED ON PERSONALIZATION* / AUTOMATIC
OFF / 5 SECONDS / 10 SECONDS / 15 SECONDS / 20 SECONDS / 30 SECONDS / *40 SECONDS* / 50 SECONDS / 60 SECONDS
Ambient light threshold for leaving-home lights
*0* / 1 / 2 / 3 / 4 / 5 / 6 / 7
YES / *NO*
Rear fog lights
YES / *NO*
Disable US side marker lights (US models only)
YES / *NO*
Other
YES / *NO*
*YES* / NO
*YES* / NO
*YES* / NO
Obtained with Carista 100099 for iOS.
Download app: http://www.caristaapp.com/ios/
locky
1,073
North East
Got my OBD dongle, Carista app, all worked very nicely. Got needle sweep on now plus a few other tweaks.
Had a go with Torque and that seemed fine too.
No faults returned from both apps.
Thanks for the info on this thread so I got the right dongle!
elnigel
217
10
Chesterfield, Derbyshire
Hi guys. I'm having issues! Please help.
I bought a Bluetooth dongle, the type recommended and it worked once then died. So I bought a wifi dongle from Amazon. Have waited eagerly for it to arrive from somewhere far away. It came today and I get 1 light on it. My iPad can't find its wifi signal!!! Looks like it's not working as neither of my laptops can see its wifi either.
Can anyone give me a recommendation of which dongle to buy. I have both android devices and an iPad. I just want one that works.
Any help appreciated, ,an ebay link to a good one or something.
Sorry for the rant, I got excited about needle sweep etc and have had my hopes dashed, sad I know!
jimbo1876
43
See my post #42 for all you need for iPad use. The dongle will only show one light initially if it is the same one as I purchased. Try an extension cable first as the wifi dongle only puts out a weak signal and can get swamped by Bluetooth signal if your car is transmitting one - they are in exactly the same frequency.
The combination I detailed in my post works consistently well for me but is quite slow in transmitting data but for the price is superb.
robt880
19
East Yorkshire
Can anyone confirm if any of these options are available on the mk4 ibiza 1.4 ? 2006 model, I quite like the idea of being able to put the windows back up by keeping the lock button pressed, some of the vw transporters do this at work however they are 61 plates not 2006 plates :whistle:
Rob.
nilz
69
Hi Guys
Just downloaded Carista and have got a bluetooth adaptor too. I managed to get it all paired up and it showed no fault codes, it also went into the customise menu, which showed lots of option, however would only save if the pro version was purchased.
I just wanted to know what happens when you pay the money, do you get another app that needs to be downloaded or how does it know that its the 'pro' version??
Nilz
camelspyyder
2 SEAT-er
Jun 26, 2014
1,307
176
Rob.
Go to Carista's website to see the options based on car type. Although The Rapid/Toledo section mentions this function, but they dont have the hardware modules to support it.
-UzY-
91
Just got the app and ordered the bluetooth dongle from amazon, eagerly awaiting my new toy.
Can't wait to turn off the annoying seat belt beep lol
nilz
69
Cool thanks mate, just wanted to know as will probably be using it on a couple of devices, guess I will just have to give it a go.
-UzY-
91
Got my OBD bluetooth dongle today, going to experiment tomorrow and will let you know of results!
-UzY-
91
Got a few mods done, got headlights as running day time lights. Beep on for locking, got rid of annoying seat belt Beep
Can't seem to reset my airbag light and fog light out sign, says it's done but isnt
Feb 6, 2014
1,323
Lincoln
Airbag light will not go out until the issue is fixed, I had the same. Usually it's the under seat connector that is at fault. Are you sure the fog light bulb is not out? Or have you replaced it with a led?
-UzY-
91
I have an issue with the front left fog light, last owner for some unknown reason decided to cut the wiring on the front fog :/?
Legojon
I only wanted a remap
5,316
2,748
Been scanning around the forums... so can I use this to change my MFD speedo to MPH instead of KMPH on a 2012 FR+?
It says:
"Speed display units KM/H / MPH"
I read elsewhere its possible by changing region which it also does:
"Instrument cluster region (affects ext. lights too)"
However I'm concerned what ext. lights changes.
I assume I pick other from the list?
"GERMANY / EUROPE/OTHER / USA / CANADA / GREAT BRITAIN / JAPAN / SAUDI ARABIA / AUSTRALIA"
