With my android note 3 and my cheap £5 Bluetooth ELM 327 odb2 an Altea 1.6 Diesel DSG I got the Carista pro and was playing with the settings managed to activate the following:
Allow configuring beep when locking/unlocking
*YES*
Beep when locking with remote
*YES*
Beep when unlocking with remote
*YES*
Gauge needle sweep at startup
*YES*
Lane-change turn signal auto-flasher count
*5 FLASHES*
Use low beams as daytime running lights
YES
Use fog lights as daytime running lights
YES
Coming-home lights
*ENABLED*
Coming-home lights mode
*MANUAL: FLASH HIGH BEAMS TO ACTIVATE*
Coming/leaving-home lights use…
*LOW BEAMS*
Coming-home lights duration
*10 SECONDS*
Turn off all lights when headlights are left on and ignition is switched off
*YES*
Flash brake lights in emergency stopping
*YES*
Brake lights work even when ignition is off
*NO*
Not working on my car that I can see:
Flash hazard lights in emergency stopping
Lower passenger-side mirror when in reverse gear (may need memory seats)
I am going to send a list to the developer to see if other settings can be activated please let me know if you have any ideas to add to this app.
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote:
Auto-lock doors when moving
*YES* / NO
Auto-unlock doors when key is taken out of ignition
*YES* / NO
Auto-lock trunk when moving
*YES* / NO
Unlock trunk when doors are unlocked
*YES* / NO
Blink turn signals when locking/unlocking with remote
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
*YES* / NO
Open/close windows and sunroof via long-press on remote
*YES* / NO
Open only driver's window via long-press on remote
YES / *NO*
Open sunroof via long-press on remote
YES / *NO*
Close sunroof via long-press on remote
YES / *NO*
Sunroof action when opening via remote
SLIDE / *TILT*
Open/close windows and sunroof by holding key in door lock
*YES* / NO
Blink turn signals when done closing windows via remote
*YES* / NO
Enable remote control buttons when ignition is on
YES / *NO*
Instruments / Display / Dings:
Instrument cluster region (affects ext. lights too)
GERMANY / EUROPE/OTHER / USA / CANADA / *GREAT BRITAIN* / JAPAN / SAUDI ARABIA / AUSTRALIA
Gauge needle sweep at startup (req. instrument cluster support)
*YES* / NO / NOT AVAILABLE
Seat belt warning
*ENABLED* / DISABLED
ENABLED / *DISABLED*
1 FLASH / 2 FLASHES / 3 FLASHES / 4 FLASHES / *5 FLASHES*
Push-to-talk (PTT) button function
PUSH-TO-TALK / *MUTE*
Lights:
Allow configuring daytime running lights via dash display
YES / *NO*
Use designated DRL bulbs as daytime running lights
YES / *NO*
YES / *NO*
YES / *NO*
Turn off daytime running lights ("wink") when turn signal is on
YES / *NO*
Turn off daytime running lights when parking brake is on
YES / *NO*
Coming-home lights
Leaving-home lights (req. auto headlights)
*MANUAL: FLASH HIGH BEAMS TO ACTIVATE* / AUTOMATIC: WHEN IT'S DARK (REQ. AUTO HEADLIGHTS)
*LOW BEAMS* / FOG LIGHTS
5 SECONDS / *10 SECONDS* / 15 SECONDS / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
*YES* / NO
Turn off front fog lights when high beams are on
YES / *NO*
Turn off rear fog lights when high beams are on
YES / *NO*
Cornering lights (using fog lights)
*YES* / NO
*YES* / NO
YES / *NO*
Other:
*YES* / NO
Auto-enable rear wiper when front wipers on and reverse gear engaged
*YES* / NO
Auto-enable rear wiper when front wipers on (interval) and reverse gear engaged
*YES* / NO
Auto-enable rear wiper when front wipers on (continuous) and reverse gear engaged
*YES* / NO
Additional 'tear' wipe after rear window washer use
*YES* / NO
Obtained with Carista 2.3 beta-3 for Android.
*YES*
*YES*
*YES*
*YES*
*5 FLASHES*
YES
YES
Coming-home lights
*ENABLED*
*LOW BEAMS*
*10 SECONDS*
*YES*
*YES*
*NO*
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
YES / *NO*
YES / *NO*
YES / *NO*
SLIDE / *TILT*
*YES* / NO
*YES* / NO
YES / *NO*
Seat belt warning
Lights:
YES / *NO*
YES / *NO*
YES / *NO*
YES / *NO*
YES / *NO*
YES / *NO*
Coming-home lights
*YES* / NO
YES / *NO*
YES / *NO*
*YES* / NO
*YES* / NO
YES / *NO*
Other:
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
