Brake pedal needs pumping...!
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
no not changed anything just gonna take it too a garage soon cos im fed up with it, my brembos keep warping disccs aswell wish id never put them on!![:@]
May 16, 2008
506
southampton
might find it could be some thing to do with the pressure of the pedal and to stop you have to push it harder and the piston comes out further and thats whats warping the disc..
when on stand still hand brake down and pushing pedal slow then fast you can hear a huffing sound do you get this with yours.. and i have been told to change the master cylinder do you know if this is a easy job..
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
why would it be the servo mine works as it should if you disconnect the servo pipe the peddle goes all hard as expected, have you had your brakes apart for refirb have you let the abs and brake system run dry???
May 16, 2008
506
southampton
no mate not taken them apart mate and when engine off my pedal goes hard. this is why im going to change the master cylinder first.
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
tbh pal you say you've checked everything else (seatcoober) so unless your m/c is feckered it might be that the m/c isn't big enough to cope with the piston sizes? (iirc you're running some other brembo's not the ibiza specific ones) maybe that could be a problem????? just you're getting down to bare roots of what's left to blame
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
provided the unions come off in theory it's easy, its just the limited room which is again the problem. for what it costs i'd take it to a garage and let them scrape their knuckles mate. I presume you have checked that your slide pins are free on the calipers seen as you're on std setup?
May 16, 2008
506
southampton
slide pins what you mean mate the piston on the caliper or some thing else
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
no the front calipers are made up of the caliper and the caliper carrier, on the std set up the carrier helps with part of the operation of the brake as it has 2 pins which are greased and the caliper slides in the carrier to help with braking, if this is siezed it will cause your brakes to be a lot weaker. if you've had them in bits you'll know what i mean.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
i had my rears off for recon maybe when i sand blasted them some sand got in the pins that have grease on but i had the covers on all the time when sand blasting and regreased the pins when they went back on, to be honest ive had this problem since i removed the rears, maybe im just blaming the fronts and its the rears that are the problem, but this does not help the fact that my brembos keep warping the front disc im puzzled.
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
you got decent discs on there? are you 'over-stomping' on the brakes because you have good ones? (daft as that sounds, if you're anything like me you love to make sure you take advantage of your mods).
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
strange you're warping them then mate, but with regards to your soft pedal problem if you've had it since you messed with the rears trey bleeding the rears up again or possible some new calipers. as you say maybe you're blaming the wrong part!
