no not changed anything just gonna take it too a garage soon cos im fed up with it, my brembos keep warping disccs aswell wish id never put them on!!
why would it be the servo mine works as it should if you disconnect the servo pipe the peddle goes all hard as expected, have you had your brakes apart for refirb have you let the abs and brake system run dry???
provided the unions come off in theory it's easy, its just the limited room which is again the problem. for what it costs i'd take it to a garage and let them scrape their knuckles mate. I presume you have checked that your slide pins are free on the calipers seen as you're on std setup?
