Brake pedal needs pumping...!
jivejester
336
A bottle I got from a shop what sells brake fluids. Just get 2 litres of fluid and follow the instructions in vagcom.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
where are the instructions you got a link, because i ran mine for 10 seconds and it only used bout a cm of fluid in the reservoir, can you go through the whole proceedure for me as i will be doing it tomorrow, before i give it to the garage, how did you do a pressure bleed thought you needed to give it to a garage????
jivejester
336
Theres no need for instructions, just make sure you have 2 x bottles to catch fluid,2 x pipes to go from the nipple to the bottles and a spanner to undo the nipples
Start the vagcom procedure as I've posted and follow the steps in vagcom to the letter, thats all you need todo.
You don't need a garage to pressure bleed the system, halfords sell a gunson pressure bleeder for a tenner that use tyre pressure.
Its not difficult.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
abs bleed using vagcom... problem solved.
wheels off floor inigtion on
Procedure for Bleeding the ABS Brake Pump on VW Golf, GTI, Jetta, and Audi TT:
[Select]
[03 - ABS Brakes]
[Basic Settings - 04]
Group 001
[Go!]
This will trigger the ABS pump to turn on for about 10 seconds. You should hear the fairly loud pump clicking during this time.
Click the [Done, Go Back] button and you're all set.
how does this proceedure use two litres of fluid, you mean do this proccedure then pressure bleed the brakes with the two litres of fluid to flush out the air???
jivejester
336
Re-read my posts..... I've already said.
Just follow the instructions, its not rocket science. I've already told you what to have handy.
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
lol there are no instructions though on bleeding the brakes using a pressure bleed kit, only on the abs bleed there are instructions on vagcom which are
[Select]
[03 - ABS Brakes]
Group 001
[Go!]
you have not said why you need two litres of fluid!!!!!
you have not said when do you open bleed nipples before during or after abs bleed!!!!
you have not said if you need bleed pipes with one way valves in them!!!!
to be honest you have not said alot really !!!!!!
jivejester
336
2 litres of fluid... too drink... what else are you going to need 2 litres of brake fluid for!?!
'Start the vagcom procedure as I've posted and follow the steps in vagcom to the letter, thats all you need todo.'
Did I not???
Though on second thoughts I'd recommend you take it too the garage and leave it too professionals.
jivejester
336
Have you actually done what I posted?
Clearly not, otherwise you wouldn't ask for instructions.
The vagcom procedure I have posted is not just turning the the pump on for 10 secs, its rather more involved and requires plenty of fluid.
Rather than ask pedantic questions, why not use the advice and it possibly may solve your spongy pedal!
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
ow so there is more to the abs bleed procedure!!!!!!! that you have not posted!!!!!!!
[Select]
[03 - ABS Brakes]
Group 001
[Go!]
BUTTON AND YOUR ALL SET this last comment suggests that the proceedure is all done and no bleeding is needed!!!!!
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
right had the brakes pressure bled still the same spongey brakes had lots of air in though, then did a full abs bleed had lots of air come out on that too, and brakes still the same brakes are crap first time you use the pedal and the brake bite is really low down but pressi it again and again and brakes are spot on i have alot of sterring wheel movment and wheel judder, could this whole thing be down to my wheel bearings that i have just replced???
Ricardo_Smooth
Powered by Apples!
Jun 26, 2007
669
sheffield
check your brake lines as i found my caliper had started to strip a thread (tarox 6 pots) causing air to start seeping in. check the hoses to make sure they are not perished/porous which run from the resovoir to the m/c.
If not for the sake of the money they cost i'd be changing master and slave cylinders as there isn't much left to blame!
Only other thingis if thereis a bias valve it may want some more front bias due to an upgrade in brakes?
danielc16
cupra R dan
May 13, 2008
327
guildford
jack the car up with the wheel up one at a time and jigle the wheel and see if there any play!! thats if your brake needs pumping up when your driving but will stay pumped up if your on a stand still, this is if there is play the disc will course the piston to go back in the cailper and you will need to pump it out if you under wot i mean!
