Originally posted by PeterS
leaving it in stock mode too
Originally posted by Garth
It cannot leave it in 'stock' mode! Maybe in preformance terms it can, but Jabba crack open the ecu and fiddle around inside. That kind of thing is noticeable, serial port tuning is not.
Originally posted by Hybrid
Might also think of a Jabba Remap, unless Revo want to alter there program!
I've got revo sps3 and it spikes over 20psi and holds 16-15psi up to 5500rpm but i also find it shockingly slow after 120 - 125mph And it wont top more than 135mph which i can also do in stock mode holding 8 - 10 psi! Just the way revo is I think all about mid range, fare play its fast as **** up to 120!!!
I know people say you dont go over 120mph, but did does ****ing piss me off when Iam doing these speeds knowing that other chipped ibizas do 150mph.....
At about 120 - 125 mph its had enough and just creeps to 135ish bit disapointing! going to have a mess about with my low boost settings and try and lower the boost spike. When driving hard I'll change 3rd and 4th at about 5500rpm because you can feel it go flat if you go any further. Got the forge intercooler to try and help the heat issue, had it vagcom'd last month and it had no faults...
From 120 on it doesnt feel any faster than stock or reach any higher speeds ...poor in my book!
I'd be interested in that too please GaryOriginally posted by Madmile
Is 135mph balls out foot to the floor maxed out. I will do some vid footage of my car at the weekend and send it to you, you can then compare it to yours and see if there is any real diff .
Originally posted by ibizacupra
If anyones got VAG-COM, could you log induction temps requested boost vs actual and ign timing for your Vmax run...
Interested to see whats going on.... and whether timing is being pulled back or something.
Bill
Originally posted by CustardCupra
The trouble wiyh the Revo cars is most who have it aint put the car on the RR so alot of BHP claims are only hearsay .
Just 'cos you've been told you have 212 bhp & 240 lbft doesn't necessarily mean its got it .
Also it depends where the BHP asnd Torque is being made in the revs,
Yeah it could be a 212 bhp car but if peak power is all over and done with at 4500rpm and the torque falls off at this point then Big Top speeds are never gonna happen .
Revo cars also seem to have a very high boost spike 21 - 22psi compared to remapped cars ( MINE BEING 16 PSI ) so heat becomes more of an issue .
More heat less power .
