awful mpg-now with logs pg4 & 5
SalSheikh
Under the Hood
Sep 2, 2009
2,760
Midlands, UK
atleast yours is working, just been told mine has a cracked valve. reaplced turbo and other bits onll to have the head off and find this issue.
Mar 3, 2009
823
Hinckley
Was VW parts or somethin like that. To be fair to him i had a reply within an hour and a new one here 2 days later.
Either way im still not sorted as my mpg is still shite. Gonna log the MAF today to check it
Mar 3, 2009
823
Hinckley
Someone mentioned previously do I have any modifications well I have a new exhaust system. Didn't click cos it looks same as oem. This gonna cause issues?
yh it was me who asked that
if you have had a exhuast isit a preformance exhuast ??
sometimes things such as exhuasts , some remaps etc can make ure cars mpg go a little bit lower so it could be your exhuast ??
what were u gettin before ? and what are you getting now ?
even if you do fit a preformance exhuast you shouldt be gettin anything less then 40 mpg
hope this help[s :D
Mar 3, 2009
823
Hinckley
Well after it was fitted I dent notice much diff in mpg. It's been bad long before that and has just been getting gradually worse. Although I never saw 40mpg I think that's a bit optimistic
dazziebear
what colour were your old plugs wen ya replaced em? you can sometimes tell by the colour if its running rich or lean.
Mar 3, 2009
823
Hinckley
Had them changed at the garage when they did service so didnt see but defo rich as post lambda sensor is reading -3.9 or -3.1 So its trying to lower the level of fuel added
My MAF reading is spot on, peaks at 202g/s on a stage 1 map from will @ p torque so thats all good.
So list of defo good
Air/Oil/Fuel Filter
Plugs
MAF
DV
Thermostat
Temp sensor
Coilpacks (ALL)
Cleaned AIT sensor
Cleaned MAF sensor also just incase
Could the fact ive had to drive with 3 coil packs running a few times for 20 miles or so to get a new one caused problems? Im just clutching at straws now.lol. Neither of the lambdas seem to change in readings, any tests i can do to check items such as these are working??
I guess the next things to try would be n249 and n75? Any others I should be checking/changing/testing? Have a mate with an s3 so easily all available
Mar 3, 2009
823
Hinckley
What should i be seeing then lee after stage 1 remap? Assume you reckon thats too high? If so you reckon thats why the car is chucking in too much fuel? MAF is reading too high so trying to fuel for those figures? Just thought that was fine as ive seen others with that figure
Mar 3, 2009
823
Hinckley
what should my pre and post cat read on idle? Also what should its voltage be?
post cat voltage im seeing 0.445v
and pre cat 1.445v
% doesnt change from 0.2% for pre and post is -5.9 on idle
Mar 3, 2009
823
Hinckley
Code:
	Group A:	'003				Group B:	'032
		RPM	Mass Flow	Load	Ign. Timing		Lambda	Lambda
	TIME					TIME
Marker	STAMP	 /min	 g/s	 %	 °BTDC	STAMP	 %	 %
	0.01	2120	18.58	12.2	31.5	0.35	0	-3.9
	0.65	2160	20.08	16.5	31.5	0.95	0	-3.9
	1.24	2280	45.81	95.3	20.3	1.55	0	-3.9
	1.85	2400	57	98	18	2.16	0	-3.9
	2.46	2560	74.22	100	15.8	2.76	0	-3.9
	3.06	2760	100.97	100	6.8	3.36	0	-3.9
	3.68	3040	135.78	99.6	8.3	3.97	0	-3.9
	4.26	3280	113.92	100	10.5	4.57	0	-3.9
	4.87	3520	122.89	100	12	5.18	0	-3.1
	5.48	3800	137.03	100	13.5	5.78	0	-3.1
	6.08	4040	144.86	100	11.3	6.38	0	-3.1
	6.68	4280	155.44	100	15	6.99	0	-3.1
	7.29	4520	163.14	100	16.5	7.59	0	-3.1
	7.89	4720	168.14	100	13.5	8.19	0	-3.1
	8.49	4960	172.86	100	14.3	8.8	0	-3.1
	9.1	5160	182.11	100	15.8	9.4	0	-3.1
	9.7	5360	188.67	100	13.5	10	0	-3.1
	10.31	5520	189.5	100	14.3	10.61	0	-3.1
	10.91	5720	198.06	99.6	15	11.21	0	-3.1
	11.51	5880	199.97	100	18	11.81	0	-3.1
	12.12	6040	201.92	100	18	12.42	0	-3.1
Code:
Group A:	'118				Group B:	'115
	RPM	Temperature	Load	Absolute Pres.		RPM	Load	Absolute Pres.	Absolute Pres.
TIME					TIME
STAMP	 /min	°C	 %	 mbar	STAMP	 /min	 %	 mbar	 mbar
4.53	2320	7	0	1040	4.22	2280	36.1	990	1060
5.14	2400	8	95.3	1110	4.83	2360	57.9	1280	1040
5.74	2560	7	95.3	1380	5.44	2480	97	2140	1240
6.34	2720	7	95.3	1720	6.04	2640	121.1	2130	1530
6.95	2960	6	92.5	2210	6.64	2800	158.6	2160	1930
7.55	3200	6	74.1	2540	7.25	3080	191.7	2170	2530
8.15	3520	6	75.3	2220	7.85	3360	191.7	2210	2340
8.76	3760	6	74.9	2260	8.45	3640	188	2230	2250
9.36	4000	6	75.3	2220	9.06	3880	190.2	2230	2240
9.96	4280	7	75.3	2220	9.66	4160	190.2	2230	2240
10.57	4480	8	74.9	2200	10.27	4360	191	2220	2210
11.17	4720	9	74.5	2190	10.87	4600	188	2200	2200
11.77	4920	9	74.9	2170	11.47	4840	183.5	2180	2210
12.38	5120	10	75.3	2180	12.08	5040	188	2160	2150
12.98	5320	12	75.7	2120	12.68	5240	179.7	2150	2170
13.58	5480	12	77.3	2110	13.28	5400	182	2140	2160
14.19	5640	14	78.4	2140	13.89	5560	182	2130	2110
14.8	5800	15	80.4	2090	14.49	5720	175.9	2120	2090
15.39	5960	15	80	2110	15.09	5880	175.9	2100	2130
runs i did yesterday in 4th
adon30
156
Brummm Brummm
Just a note. I had my car tracked the other day. I know it doesn't sound like help on your engine but stay with it. Whilst the car was in the air I noticed the Cat baffle was only hanging on by two screws. When we went to fix this we noticed that the wires that lead to the pre/post cat sensors had been touching nicely on the exhaust. There is a piece of heat protective shielding on these but it was starting to burn through and was onto the cable.
I haven't checked what my sensors are reading yet but it's worth a thought for you. Hopefully I haven't got a problem with them but I need to check at some stage.
Mar 3, 2009
823
Hinckley
Just had a read up on lambda sensors and they should read a voltage between 0.2v and 0.8v (lean to rich) so will do a log tomorrow
on block 32 im getting 0-0.2% adjustment on idle so spot on but -3.9/-3.1 on boost so its defo a faulty part just what
which lambda does block 32 refer to? pre or post cat?
823
Hinckley
I had my rear lambda changed as it was dead, would only fluctuate every now and then.
My mpg round town is better, i can see 28-29mpg which is what it used to be when i first had it mapped but its when im on the motorway or dual carriageway i see about 22mpg which is slightly confusing.
I assume its cos throttle is open more on motorway/dual carriageway. I am still seeing 5mpg in each gear when i put my foot down but used to read 5,5,13,13,13 on full throttle after remap so there is clearly something wrong
adon30
156
Brummm Brummm
I'm also confused with you seeing worse figures on dual carriageways/ motorways. On my way to and from work this is where I gain all my mpg as I'm maintaining a steady speed with a nice warm engine. I guess you are using the onboard computer to get mpg figures? Does the remap have an effect on what these read? Either way what you are seeing has confused me unless you are toe ending it on short motorway runs rather than longer steady runs. At least your ironing out all the little glitches in the car.
