Alex's ovni yellow k03s Take 2!!!
Aug 8, 2010
706
greenock
not updated this in a while, been busy with my new job and other things so the car hasnt had as much time spent on it as id like to!!
only real difference is new wheels i picked up, set of 5 seat sport super Ts, fit over the 312mm brakes no bother and changed the look a wee bit so quite chuffed, going to get them refurbished after winter as there in a bit of a state atm!
tight fit!!
and fitted
plans are to get a FMIC asap thinking of doing custom pipework eventually and welding it up myself in work but not sure yet! then downpipe and stage 2 map!
immediate plans are to service it when weather improves and get it in to get belts etc done
J20ROBO
303
Ayrshire
Tight fit haha! brings back memories wen a last bught a set of 5 19's got the boot suit and no more!!!
Looks good with new shoes on.. hows the clearance between caliper and alloy???
Aug 8, 2010
706
greenock
clearance is far better now between calliper face n inside of the spokes but still just as tight around the outside haha will try n get a pic once the weathers a bit better n i paint the callipers! want to refurb the wheels in gloss black with yellow seat sport n OZ stickers on them! couldnt imagine tryin to fit 19s in a car aha 16s were hard enough although the strut brace didnt do me any favours!! was shittin it every time i had to brake lol. going to get the b pillars done black again will need to order the vinyl off of david at sere at some point. think ill be getting rid next summer though really fancy a platinum LCR but if the ibiza stays it will be getting the gt28 treatment without a doubt[B)]
Aug 8, 2010
706
greenock
made a purchase the other night hopefully get it fitted as soon as i can get a map tube etc!
should sort my cooling problem, not sure where i will mount my plate right enough?? any suggestions??
Aug 8, 2010
706
greenock
Was thinkin that steve but not sure it would look right with my private plate! Was thinking of making brackets n mounting it at the side nearer the bottom or in the middle at the bottom, will have a play about n see what looks good need to make it fit first!
Aug 8, 2010
706
greenock
Yeah matt took a wee bit, dont think the people behind were happy lol!! Not sure when front mount will be on, need a map sensor tube and to make my mind up how im doing the pipework, might try n get hold of some stainless n weld it up myself in work or college, cant be bothered with the hassle of hoses popping off and losing boost. Only problem is tryin to get in and out the yard with a few feet of stainless pipe lol doubt security would be happy!! Changed oil, filters and plugs last weekend before i went to wales, the last plugs werent in overly long and were still quite clean but got ngk bkre7 iirc ( the ones everyone reccomends) and its running nice and smooth again! Going to get belts sorted, b pillar vinyls and refurb wheela brakes next then next year will be big turbo or new car i think!!
706
greenock
Will put it on when i have map sensor tube and a couple other bits n pieces. Cant stop looking at cars for sale atm though!! Need to find the love again
