8bit's Mk1 Leon Cupra R. Scarlett - as in Johansson...
8bit
3,401
Aberdeen
On the rollers again, not so good :(
Was at a RR day again today, pretty disappointed with the results. Showing about 28bhp down from what it should be as standard, probably more so given the Jetex and TIP. Fuelling still looking lean as well, the operator there said even if that's all the ECU is requesting then that'll be because there's something else wrong.
To be honest I'm a bit sick of this now and in two minds again whether to spend (waste?) time trying to sort it or just get shot of the car and get something else.
Graphs here anyway:
KatCowie
OEM Lover
Jun 23, 2007
1,364
Inverurie, Aberdeenshire
Cheers :) Yep as wayne says the earlier ones were called Flash Red, the later ones are called Emocion Red, which is slightly darker, richer shade than Flash. Never met anyone with a Flash Red car but would be interesting to put them side by side and get a shot with a good camera to really see the difference.
While I'm here, no real progress lately but have been enjoying being able to drive the car properly again (well as properly as I can, I'm far from a great driver) now that the weather's a bit better and the car is running well. This month will be sore, got road tax, MOT and insurance all due :( On the upside I'm going to get my R32 front ARB fitted while its' in the garage anyway so once that's on and I'll hopefully have some free funds after that, I'll be getting a rear one to go with it. Then to pick a remap...
You can meet mine in summer, it's Flash Red :)
8bit
3,401
Aberdeen
Cool, did see yours at the SCN RR night at Wallace that time but obviously it was dark by the time we got there so couldn't tell it was a different shade of red!
Wee update - Car's going in to the garage today to get MOT'd and hopefully (if the MOT doesn't require expensive work) also finally get my R32 front ARB fitted. Also, after speaking with a local tuner I think we've got a better idea what's causing it to run lean so hopefully there's some light at the end of the tunnel for that. With any luck I'll get the 28 - 30bhp I'm missing at the top end back :)
8bit
3,401
Aberdeen
Proper update - R32 front ARB fitted at last :) Haven't really had a chance to give it any real stick yet but can already feel a difference. Hard to explain, there's an improvement in steering at speed, I don't feel like the car is fighting against me turning the wheel like before and I definitely feel more confident with it. The roads here are still pretty slimy and covered in grit from the recent snow and I'm conscious that I don't have a rear ARB yet and still have crappy tyres on the rear so didn't want to push it too far but will be getting these things sorted soon too.
And some more good news, the car breezed through the MOT, not even a single advisory :) Good job too as road tax and insurance are all due this month as well.
Just need to work out why it's running lean and I'll be a happy bunny again.
8bit
3,401
Aberdeen
I haven't been to see him yet, did speak with him on the phone though. He reckons it's likely to be the fuel pump or FPR. Hopefully will get a chance to get to see him soon.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Fingers crossed it works out so you can progress with this project into bigger and better things.
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
Oh and meant to say - thanks Willie for putting me on to the R32 ARB, well worthwhile mod :)
It certainly is, good to see the car fly through the MOT despite the problems you've been having. I thought that would have been it for the car after the poor showing on the rollers. Fingers crossed you get it sorted. Your lucks got to change soon surely!
8bit
3,401
Aberdeen
Cheers mate! Well it's basically one (or more) of the fuel pump, filter (changed that already), injectors or FPR, or I guess a split hose to the FPR as well so I guess there's light at the end of the tunnel.
No bother, I've got a whole list of other worth while mods too if you want it, lol
Next thing will be a rear ARB, probably a Whiteline 24mm adjustable. Can't stretch the extra £100 for a Neuspeed while we're meant to be buying a house and I figure the Whiteline will do for my purposes, bit of fast road and maybe a trackday or two in the future.
After those I'm sure I'll pick your brains some more at the local meets as usual, lol!
8bit
3,401
Aberdeen
Right, managed to spend a bit of time on the car at the weekend so a little update is in order. On Saturday I had the help and wisdom of a local tuner (Willie, you know who I mean) who logged my car to try and find out why its' still running lean at higher revs. Looks like it's probably the fuel pump, I've changed the filter since I first discovered this and apparently it's very unlikely to be the FPR.
So I've asked David at Seremotors for a price for an OEM fuel pump, then I'll see if I can change it myself. Logs are below, block 001 shows that the ECU is trying to add more fuel because it's detecting that not enough is getting to the engine, can see this is causing a bit of knock at high RPMs. Not good.
Code:
'001				Group B:	'115				Group C:	'020
RPM	Temperature	Lambda	Bin. Bits		RPM	Load	Absolute Pres.	Absolute Pres.		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
				TIME					TIME
 /min	°C	 %		STAMP	 /min	 %	 mbar	 mbar	STAMP	°KW	°KW	°KW	°KW
1840	75	3.1	11101010	0.61	1920	92.5	1770	1190	0.02	0	0	0	0
2000	75	0.8	11101000	1.52	2080	113.5	1890	1380	0.92	0	0	0	0
2240	75	1.6	11101000	2.42	2360	138.3	1870	1680	1.81	0	0	0	0
2520	75	7.8	11101000	3.33	2640	157.1	1790	1910	2.73	0	0	0	0
2800	75	4.7	11101000	4.24	2920	154.1	1770	1820	3.63	0	0	0	0
3120	75	5.5	11101000	5.14	3200	148.1	1770	1780	4.54	0	0	0	0
3400	75	4.7	11101000	6.05	3480	151.9	1800	1790	5.44	0	0	0	0
3680	75	3.1	11101000	6.95	3800	153.4	1790	1790	6.35	0	0	0	0
3960	75	3.9	11101000	7.86	4040	151.1	1770	1790	7.25	0	0	0	0
4240	75	4.7	11101000	8.76	4320	151.9	1780	1790	8.16	0	0	0	0
4480	75	5.5	11101000	9.67	4560	146.6	1790	1800	9.06	0	0	0	0
4720	75	3.9	11101000	10.57	4800	146.6	1780	1760	9.97	0	0	0	0
4960	75	5.5	11101000	11.48	5040	148.9	1790	1790	10.87	0	0	0	0
5200	75	4.7	11101000	12.38	5280	153.4	1830	1820	11.78	0	0	0	0
5440	76	3.9	11101000	13.29	5480	153.4	1870	1820	12.68	0	0	0	0
5640	76	4.7	11101000	14.2	5720	160.2	1890	1860	13.59	0	0	3	0
5840	76	3.9	11101000	15.1	5920	153.4	1880	1910	14.5	0	0	3	0
6040	76	1.6	11101000	16.01	6080	150.4	1840	1880	15.4	0	0	2.3	0
6200	76	-9.4	11101000	16.92	6240	140.6	1800	1850	16.31	0	0	2.3	5.3
6320	77	0	11100000	17.82	6360	132.3	1700	1750	17.22	0	3	7.5	8.3
6440	76	0	11100000	18.72	6480	124.1	1620	1630	18.13	0	3	9	8.3
Got my replacement el-cheapo VAGCOM cable (original one was faulty) from the ebay seller today so hopefully I'll be able to log the car once I've changed the pump.
So then on Sunday I gave the car its' first proper wash of the year. Should have taken some before pics but it was an utter disgrace. The footwells looked like someone had laid a stonechip driveway in them so hoovered it all out then a proper two-bucket wash, rinse and dry outside. Got some Autoglym tyre dressing from Halfords but it didn't seem to make the tyres look any better so was a bit annoyed about that. Then it rained and snowed all day today so they'd have ended up looking mingin again anyway.
Couple of quick and ropey phone-cam shots, just cos it looked nice and shiny.
Lastly, am enjoying the R32 front ARB. On its' own it's a subtle improvement for sure, but the steering is definitely a bit more responsive and the car doesn't feel like it's straining against you through the steering wheel. Going to order a rear one to go with it at the end of the month :)
So will need to get something better for dressing the tyres for next time. Any of the detail-fiends reading this, I'm open to suggestions, also looking for something good to clean the insides and outsides of the windows.
Last, just bought a new set of alloy center caps off a member on here so will replace the old, tatty ones when I next wash the car.
EDIT - knew I forgot something... Noticed today one of my headlight bulbs had gone so ordered some Osram Nightbreaker plus ones which will hopefully look and illuminate better, and some sidelights while I was at it to replace the horrible yellow LED ones I bought by mistake last time...
dav
SEAT owner no more...
Feb 2, 2006
1,077
Kincardineshire, scotland
this thing is really nice bud! shame you have had so much **** with it tho, but stick with it! :)
edit- if your binning the old caps! i will take them! need ones for my winters.
8bit
3,401
Aberdeen
Cheers Willie, I've been out there and bought some things before, they are very helpful (think it was Rich I spoke to) but they obviously sell loads of different products so was just after something recommended by an end-user so to speak. Will probably go there to buy it tho, shame they're not open on Saturdays.
Might be worth trying the FPR, yeah. You about this weekend?
8bit
3,401
Aberdeen
Cheers dav, feel like there might be light at the end of the tunnel now, hopefully it's not a train :) Will the LCR center caps fit your wheels? They're yours if you want em mate but they're pretty scruffy looking, fine for winters tho I guess.
dav
Feb 2, 2006
1,077
got a few sets i have for winter so might fit one of them hopefully. get it mapped asap too then you will no longer be getting left behind (as per an earlier post)
