which tuners are pushing this on then? v. interested for the new year!
if your genuinley looking at 400hp on a hybrid k04, the GT28 conversion really does seem pretty pointless...
Statllers own car's running GIAC software.
Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Is this the same rollers that Hurdy goes to![]()
Saturday 26 June 2010 13:02:25
1P0 907 115 C 2.0l R4/4V TFSI 0020
Group A: '003 Group B: '020 Group C: '004
Engine Speed Intake Air Mass Throttle Drive Ignition Cylinder 1 Ignition Cylinder 2 Ignition Cylinder 3 Ignition Cylinder 4 Ignition Engine Speed Voltage Supply Coolant Intake Air
TIME Angle Sensor 1 Timing Angle TIME Angle Delay Angle Delay Angle Delay Angle Delay TIME Temperature Temperature
Marker STAMP /min g/s % °ATDC STAMP °KW °KW °KW °KW STAMP /min V °C °C
0.02 720 2.81 2 -3 0.06 0 0 0 0 0.21 760 14.194 81 29
0.34 720 2.47 1.6 -3.8 0.46 0 0 0 0 0.59 720 14.1 81 29
35.56 2760 15 7.5 -4.5 35.7 0 0 0 0 35.44 2920 14.194 83 21
35.96 2640 23.89 17.3 17.3 36.09 0 0 0 0 35.84 2680 14.1 83 21
36.35 2720 47.86 25.9 23.3 36.48 0 0 0 0 36.23 2680 14.194 83 21
36.75 2840 57.22 25.1 23.3 36.9 0 0 0 0 36.6 2800 14.1 83 22
37.13 2960 46.03 20.4 24 37.28 0 0 0 0 37.03 2920 14.194 83 22
37.52 3080 42.11 18.4 25.5 37.65 0 0 0 0 37.4 3040 14.1 83 22
37.91 3120 19.17 12.9 35.3 38.06 0 0 0 0 37.79 3120 14.194 83 22
38.32 3160 22.03 14.1 36 38.44 0 0 0 0 38.18 3160 14.1 83 21
44.93 3200 10.75 7.8 24 45.06 0 0 0 0 45.2 3200 14.194 84 23
45.32 3240 21.17 17.6 0 45.45 0 0 0 0 45.58 3280 14.1 84 23
45.74 3320 73.81 67.1 18 45.86 0 0 0 0 45.97 3440 14.006 84 23
46.1 3560 146.17 99.6 7.5 46.23 0 0 0 -3 46.35 3800 14.1 84 24
46.49 3920 191.92 99.6 9.8 46.6 -6 -3 -3 -3 46.76 4160 14.1 84 24
46.9 4280 206.22 99.6 7.5 47.01 -6 -6 -6 -6 47.14 4480 14.006 84 24
47.28 4680 219.56 99.6 6.8 47.41 -5.3 -6.8 -5.3 -6 47.53 4840 14.1 84 24
47.65 4960 224.53 99.6 7.5 47.79 -5.3 -6.8 -5.3 -6 47.97 5160 14.1 84 24
48.1 5320 238.56 99.6 10.5 48.23 -8.3 -6.8 -5.3 -6 48.37 5520 14.1 84 24
48.49 5640 249.53 99.6 9.8 48.61 -8.3 -6.8 -5.3 -6 48.75 5800 13.912 84 24
48.9 5960 257.19 99.6 3 49.04 -8.3 -6.8 -5.3 -6 49.16 6080 13.912 84 24
49.29 6200 264.81 99.6 3.8 49.41 -8.3 -6.8 -5.3 -6 49.53 6320 14.1 84 24
49.66 6360 263.14 99.6 12.8 49.79 -7.5 -6 -4.5 -5.3 49.93 6560 13.912 84 24
50.06 6640 264.14 99.6 10.5 50.17 -9 -6 -4.5 -5.3 50.3 6800 13.912 84 25
50.44 6880 264.83 99.6 11.3 50.57 -9 -6 -4.5 -5.3 50.7 5960 14.006 84 25
50.82 4920 170.69 98.8 13.5 50.97 -9 -6 -4.5 -8.3 51.08 5200 14.006 84 25
51.19 5280 246.86 99.6 12 51.33 -8.3 -5.3 -3.8 -8.3 51.48 5400 14.006 84 26
51.6 5440 254.03 99.6 7.5 51.72 -8.3 -5.3 -6.8 -8.3 51.85 5520 14.006 84 27
51.98 5600 258.31 99.6 8.3 52.11 -8.3 -5.3 -6.8 -8.3 52.24 5680 14.1 84 27
52.36 5720 257.92 99.6 11.3 52.5 -7.5 -4.5 -6 -7.5 52.63 5840 14.006 84 27
52.76 5880 263.5 99.6 12.8 52.88 -7.5 -4.5 -6 -7.5 53 6000 13.912 84 28
53.13 6040 262.22 99.6 12 53.26 -7.5 -4.5 -5.3 -7.5 53.38 6120 14.1 84 28
53.52 6160 267.58 99.6 11.3 53.65 -6.8 -3.8 -5.3 -6.8 53.77 6240 13.912 84 28
53.9 6280 266.94 99.6 12 54.05 -6.8 -3.8 -5.3 -6.8 54.17 6400 13.912 84 29
54.29 6440 271.11 99.6 12.8 54.43 -6 -3 -4.5 -6 54.58 6480 14.006 84 29
54.7 6520 270.56 99.6 13.5 54.83 -6 -3 -4.5 -6 54.95 6600 13.912 84 30
55.09 6680 268.33 99.6 13.5 55.22 -6 -3 -4.5 -6 55.34 6720 14.006 84 30
55.47 6760 268.81 99.6 14.3 55.6 -5.3 -2.3 -3.8 -5.3 55.74 6800 14.006 84 30
55.86 6840 263.86 99.6 14.3 55.98 -5.3 -5.3 -3.8 -5.3 56.13 6120 14.1 84 30
56.25 5320 185.92 97.6 14.3 56.37 -4.5 -5.3 -3 -4.5 56.5 5400 14.1 84 30
56.64 5440 246.11 99.6 8.3 56.76 -7.5 -5.3 -3 -4.5 56.89 5400 14.006 84 31
57.01 5400 49 8.6 33 57.15 0 0 0 0 57.29 5360 14.006 84 28
57.42 5200 24.89 11.4 4.5 57.54 0 0 0 0 57.69 5080 14.006 84 27
81.5 2960 122.92 99.6 7.5 81.24 0 0 0 0 81.37 2840 14.194 83 27
81.88 3280 166.36 99.6 9 81.63 0 0 0 0 81.76 3160 14.1 83 27
82.26 3680 176.08 99.6 8.3 82.02 0 0 0 0 82.15 3560 14.1 83 27
82.66 4040 187.36 99.6 11.3 82.4 0 0 -2.3 -4.5 82.53 3920 14.006 83 27
83.04 4360 201.03 99.6 7.5 82.79 -3 -6 -2.3 -4.5 82.91 4240 14.006 83 27
83.42 4640 207.97 99.6 10.5 83.18 -3 -6 -2.3 -4.5 83.3 4600 14.1 83 27
83.78 5000 224.67 99.6 11.3 83.52 -3 -6 -2.3 -4.5 83.65 4840 13.912 83 27
84.17 5240 231.03 99.6 12 83.91 -3 -6 -2.3 -4.5 84.03 5160 14.1 83 27
84.56 5560 245.75 99.6 12 84.3 -2.3 -5.3 -4.5 -3.8 84.43 5520 14.006 83 27
84.95 5880 255.75 99.6 12 84.7 -2.3 -5.3 -4.5 -3.8 84.83 5760 13.912 83 27
85.34 6120 262.03 99.6 14.3 85.07 -5.3 -5.3 -4.5 -3.8 85.22 6040 14.006 83 27
85.74 6360 263.86 99.6 15.8 85.47 -5.3 -5.3 -4.5 -3.8 85.59 6320 14.1 83 27
86.12 6600 261.44 99.6 14.3 85.86 -5.3 -5.3 -3.8 -3 86 6600 14.006 83 27
86.51 6760 260.72 32.2 7.5 86.26 -5.3 -5.3 -3.8 -3 86.39 6800 14.006 83 27
86.9 5800 22.06 11.8 8.3 86.64 0 0 0 0 86.78 6040 14.194 83 27
87.28 5120 19.06 12.2 4.5 87.02 0 0 0 0 87.13 5400 14.1 83 25
87.65 4560 16.69 11.4 0.8 87.4 0 0 0 0 87.52 4760 14.194 83 24
88.04 4400 16.06 11 0 87.79 0 0 0 0 87.92 4360 14.1 83 24
88.43 4240 16.25 11 -0.8 88.16 0 0 0 0 88.31 4280 14.1 83 24
88.85 4040 15.83 10.6 -2.3 88.55 0 0 0 0 88.69 4120 14.194 83 24
89.22 3880 14.64 10.2 -2.3 88.97 0 0 0 0 89.1 3920 14.194 83 24
89.61 3720 13 9.4 -3 89.37 0 0 0 0 89.49 3760 14.194 83 24
90.02 3520 12.89 9 -3 89.74 0 0 0 0 89.88 3600 14.1 83 24
90.41 3360 12.03 8.6 -3.8 90.14 0 0 0 0 90.27 3400 14.1 83 24
90.79 3200 11.5 8.2 -3.8 90.53 0 0 0 0 90.67 3240 14.1 83 24
91.17 3040 10.69 7.8 -3.8 90.93 0 0 0 0 91.06 3080 14.1 83 24
91.54 2920 10.61 7.5 -4.5 91.3 0 0 0 0 91.41 2960 14.1 83 24
91.91 2840 10.11 7.5 -4.5 91.66 0 0 0 0 91.78 2880 14.1 83 24
92.3 2760 9.92 7.1 -4.5 92.05 0 0 0 0 92.18 2760 14.194 83 24
92.69 2680 9.25 6.7 -4.5 92.43 0 0 0 0 92.57 2720 14.194 83 24
93.08 2640 9.17 6.7 -4.5 92.82 0 0 0 0 92.94 2640 14.194 84 24
93.46 2560 9.31 6.7 -4.5 93.21 0 0 0 0 93.34 2600 14.194 84 25
93.83 2560 9.22 6.3 -4.5 93.59 0 0 0 0 93.7 2560 14.194 84 25
94.22 2520 8.86 6.3 -4.5 93.95 0 0 0 0 94.09 2520 14.194 84 25
94.59 2480 8.14 5.9 -4.5 94.32 0 0 0 0 94.45 2480 14.194 84 25
94.95 2440 8.31 5.9 -4.5 94.72 0 0 0 0 94.84 2440 14.194 84 25
95.34 2400 8.19 5.9 -4.5 95.09 0 0 0 0 95.22 2440 14.194 84 25
95.73 2400 7.97 5.9 -4.5 95.47 0 0 0 0 95.61 2400 14.194 84 25
96.11 2360 8.06 5.5 -4.5 95.85 0 0 0 0 95.96 2360 14.194 84 25
96.48 2360 11.86 8.6 36 96.23 0 0 0 0 96.35 2400 14.1 84 25
126.23 2560 34.19 16.9 24 125.97 0 0 0 0 126.09 2400 14.194 84 27
126.6 2520 15.94 6.3 -6.8 126.35 0 0 0 0 126.48 2600 14.194 84 27
213.68 5520 239.86 99.6 9 213.81 -4.5 -6.8 -4.5 -5.3 213.57 5360 13.912 81 27
214.08 5720 250.97 99.6 9.8 214.2 -4.5 -6.8 -4.5 -5.3 213.93 5640 13.912 81 27
214.45 6000 253.03 99.6 10.5 214.63 -4.5 -6.8 -4.5 -5.3 214.32 5920 13.818 81 27
214.88 6320 263.69 99.6 10.5 214.99 -4.5 -6.8 -4.5 -5.3 214.76 6160 13.912 81 28
215.24 6520 263 99.6 9.8 215.37 -4.5 -6.8 -4.5 -5.3 215.12 6400 13.724 81 28
215.64 6720 266.72 99.6 10.5 215.76 -4.5 -6.8 -4.5 -5.3 215.49 6600 13.912 81 28
216.01 5880 194.47 99.6 13.5 216.14 -4.5 -6.8 -4.5 -5.3 215.88 6240 13.818 81 29
216.4 5120 239.06 99.6 8.3 216.52 -4.5 -6.8 -4.5 -5.3 216.27 5080 13.724 81 29
216.79 5320 249.19 99.6 8.3 216.91 -3.8 -6 -3.8 -5.3 216.67 5240 13.912 81 30
217.18 5440 256.31 99.6 8.3 217.3 -3.8 -6 -3.8 -4.5 217.04 5400 13.818 81 30
217.55 5560 255.69 99.6 9.8 217.7 -3.8 -6 -3.8 -4.5 217.43 5480 13.912 81 30
217.96 5720 259.61 99.6 9.8 218.08 -3 -6 -3 -4.5 217.82 5680 14.006 81 30
218.36 5320 39.22 6.7 6 218.49 0 0 0 0 218.23 5480 13.912 81 31
218.76 4680 20 10.2 1.5 218.88 0 0 0 0 218.61 4920 14.1 81 30
219.13 4160 17.22 10.2 -0.8 219.23 0 0 0 0 219 4320 14.006 81 27
219.5 3560 13.06 9.4 -3 219.62 0 0 0 0 219.38 3800 14.1 81 27
219.89 3600 12.36 9 -3 220.01 0 0 0 0 219.75 3600 14.1 81 27
220.27 3600 13.36 9 -3 220.41 0 0 0 0 220.14 3600 14.1 81 27
220.66 3560 13.56 9 -3 220.79 0 0 0 0 220.54 3560 14.1 81 27
221.05 3520 12.83 9 -3 221.18 0 0 0 0 220.92 3560 14.1 81 27
221.44 3520 12.61 9 -3 221.57 0 0 0 0 221.29 3520 14.194 81 27
221.82 3480 12.64 9 -3.8 221.95 0 0 0 0 221.69 3480 14.1 81 27
222.21 3480 12.86 9 -3.8 222.33 0 0 0 0 222.08 3480 14.1 81 27
222.59 3440 12.47 8.6 -3.8 222.72 0 0 0 0 222.46 3440 14.1 81 27
222.98 3400 12.78 8.6 -3.8 223.11 0 0 0 0 222.84 3400 14.1 81 27
223.36 3360 11.64 8.6 -3.8 223.49 0 0 0 0 223.23 3400 14.1 81 27
223.75 3360 11.69 8.6 -3.8 223.87 0 0 0 0 223.61 3360 14.1 81 27
224.14 3320 11.64 8.6 -3.8 224.26 0 0 0 0 224.01 3320 14.1 81 27
224.61 3280 11.81 8.6 -3.8 224.73 0 0 0 0 224.39 3280 14.1 81 27
224.98 3200 11.64 8.2 -3.8 225.11 0 0 0 0 224.86 3240 14.1 81 27
225.37 3200 10.83 8.2 -3 225.49 0 0 0 0 225.25 3200 14.1 81 27
225.74 3160 11.58 8.2 -3.8 225.87 0 0 0 0 225.62 3160 14.006 81 27
226.14 3120 10.89 8.2 -3.8 226.26 0 0 0 0 225.99 3120 14.194 81 27
226.51 3080 11.11 7.8 -3.8 226.65 0 0 0 0 226.38 3120 14.1 81 27
226.89 3080 10.97 7.8 -3.8 227 0 0 0 0 226.77 3080 14.194 81 27
227.26 3040 11.19 7.8 -3.8 227.38 0 0 0 0 227.11 3040 14.1 81 27
227.63 3040 10.69 7.8 -3.8 227.77 0 0 0 0 227.5 3040 14.1 81 27
228.02 3000 10.78 7.8 -3 228.14 0 0 0 0 227.89 3000 14.1 81 27
228.41 3000 10.75 7.8 -3.8 228.53 0 0 0 0 228.29 3000 14.1 81 27
228.8 2960 10.36 7.5 -4.5 228.92 0 0 0 0 228.66 2960 14.1 81 27
229.18 2920 10.31 7.5 -4.5 229.31 0 0 0 0 229.04 2920 14.1 81 27
229.57 2920 10.5 7.5 -4.5 229.69 0 0 0 0 229.43 2920 14.1 81 27
229.96 2880 10.11 7.5 -4.5 230.08 0 0 0 0 229.83 2880 14.1 81 27
so is this 400bhp K04 all just dreaming then?
By the way, for what its worth, I know of at least 5 or 6 failures on S2+ cars now ranging from Cylinder Head Gasket failures to Piston/Piston Ring problems which have scored the engine to the point that its BER.
At least 2 of these cars have had complete new engines (A Cupra and an S3).
